dear Team
could you pls support below error massege s4c controller while movement manual or motor on
dear Team
Does this happen only when the motor power turns on?
dear Team
I think that robot electrical maintenance has not been done for a long time. Check the diagram of the K1-2-3 contactors next to the main switch. Probably 24V or 380V transitions cannot be made correctly. If these are normal, you can check the drivers below. Usually 346G drives fail.
Alternatively, if you have system disks, you can reinstall the system.
dear Team
I am also facing the same issue. Did your problem got solved?
