Kindly help with the procedures to be done after changing the Encoder battery . The robot is YS002N B .
If it possible please help with Arm Zero and Motor Replacement Manual.
Thank you in advance .
Attached are the required documents which include:
- Battery replacement.
- Zeroing.
Usually the encoder battery replacement procedure does not affect ANY zeroing if done correctly and before the battery is exhausted - that is a 5 minute job.
If you are a Kawasaki client, you can sign up to the Kawasaki Download Centre where all manuals are freely available, follow the link below:
Thank you very much !
Your welcome.
