  4. Kawasaki Robot Forum
P0100 ERROR- Illegal Input Data for Seam tracking Arc welding program
  • vijaykumar gabriel
  • January 25, 2023 at 4:15 PM
    Hello All,
    I created an Arc welding program for E series controller with Laser point seam searching. The point sense seems to work good but for some reason I am getting an P0100 error- Illegal input data error, I am not sure where to search the right data being set to the controller for
    SET_ARC_W2JOBNO 1= 101 # Job condition 1 for indupt data 101,
    Can someone help me where to check the data in the Controller
    Edited once, last by vijaykumar gabriel (January 25, 2023 at 4:26 PM).
    • January 25, 2023 at 4:26 PM
    This is the error that I am getting when loading the program
  • kwakisaki
    694
    4,770
    • January 25, 2023 at 8:47 PM
    Your TOOL variable name is too long (>15 characters) but wouldn't attribute to the error.
    SETCONDW1 and SETCONDW2 can be found in Aux 1401 Weld Conditions.
    Not 100% sure on your error during the load though, the error is pointing to the below explanation:
    What E controller is it and do you have up to date firmware loaded?
    Check out Aux 0804 and post the screenshot and I can check your current revisions?
    • January 26, 2023 at 4:40 PM
    Hello Kwakisaki,
    Thanks for the reply, I found out the issue. It is because I set wrong job number for SET_ARC_W2JOB 1.
    I used the READ_ARC_WxJOBNO command to read the parameters for a specific job number.
    I came to know that the 101 job number was not assigned .
  • kwakisaki
    694
    4,770
    • January 26, 2023 at 4:49 PM
    Not too sure what you mean about READ_ARC_WxJOBNO command as it doesn't exist as a command and isn't in your code snippet you provided.
    But if you've sorted it, then that's the important thing.
    Thanks for letting us know you've resolved it.
  • seam finding
  • weld condition
  • Crater
