  4. Kawasaki Robot Forum
Newly acquired Kawasaki UX150 with C-Controller
  • DoesItExist
  • January 24, 2023 at 10:59 PM
  • DoesItExist
    19
    57
    • February 17, 2023 at 6:22 PM
    • #41
    I'm providing 3x400V (measured approx 420V).
    I managed to clear the issue and move it again, I took a few videos. I'll upload them this evening. I'm having the position envelope error after moving it a bit at the moment
  • kwakisaki
    694
    4,760
    • February 17, 2023 at 6:35 PM
    • #42
    Quote from DoesItExist
    I'm guessing It's an other movement mode I can activate by pressing joint interpolation in the teach block menu on the TP ?
    That's correct.
    Whenever you are checking individual joints for issues, always use Joint interpolation not base or tool.
    Yes, just hearing a click from the brake does not necessarily the mechanical part is releasing internally, only real way is try and move the joint by hand during the brake release button press/hold.
    Ok about the supply.
    Some video would be good and if you can capture these noises and where they are coming from would be good to.
    With which joint?
    Can you try the other joints individually rather than concentrating just on JT5.
  • DoesItExist
    19
    57
    • February 17, 2023 at 7:17 PM
    • #43
    Hello kwakisaki,
    I tried to activate joint interpolation but had an error saying "no program"...
    I uploaded the videos:
    Video 1
    External Content youtube.com
    robot functionning until error 1504 while moving JT3
    Video 2
    robot functionning until error 1504 when moving JT4
    Video 3
    robot functionning until error 1504 when moving JT4. Inconsistent grumbling noise can be heard from the servor
    Video 4
    robot functionning until error 1504 when moving JT5
    Video 5
    Whirring sound heard from the servos
    Video 6
    Weird noise heard from the servos, brake engaging ?
    All the errors 1504 are on JT5, no matter what servo was moving when the error occured.
    I've been tring to clear the current overload for half an hour to get these videos, in the end I managed to clear it by:
    -Unplugging X5
    -Restarting the control box
    -Pressing "clear errors" many times
    -Once cleared, I plugged X5 back in
    -Restarted the control box
    Now the robot is running but the 1504 error pops up spontaneously. I didn't get the overcurrent error again yet.
    I'm starting to consider trying voodoo magic :wallbash:
  • kwakisaki
    694
    4,760
    • February 17, 2023 at 8:00 PM
    • #44
    It'll end up being something obvious that's been overlooked.
    Has nothing to do with that.
    From the videos it looks like your jogging it in joint interpolation mode.
    That mode is changeable on the teach screen your using, bottom to the left of the joint keys.
    But do all your testing in joint anyway.
    If I am hearing it correctly, it sounds like a sack of cats, but the audio is not too clear if I'm honest.
    So the amp overcurrent is keeping quite at the moment......we'll take that for now.
    Have you checked/cleaned F5 MCB?
    Are you in a position to make a file save yet and post it here?
    Is there not much room to move it in there?
    You really to be able to fully test the joints working envelope, just operating it in that crunched posture is not good as it's been out of service for ages, really need to stretch her out.
  • DoesItExist
    19
    57
    • February 20, 2023 at 10:43 AM
    • #45
    Hello kwakisaki,
    Yes I checked and cleaned F5, I can connect the laptop to the robot so I'll make a save file and post it here as soon as it's done!
    I have absolutely no room, I'm currently looking for a bigger shop but I'm not quite there yet...
    I was planning on storing it until I get a bigger shop and enough room for it.
  • kwakisaki
    694
    4,760
    • February 20, 2023 at 11:32 AM
    • #46
    The reason for the backup, is so the next step will be to hardware initialize the robot and set it up to a minimum configuration to test it without the previous configuration information.
    This way we can rule out any existing settings creating these issues.
    I suspect this is not software related, but doesn't harm it if we remove her memory and any old ghosts she may be keeping hold of.
    If this doesn't yield anything, then we can load the backup back in afterwards.
  • DoesItExist
    19
    57
    • February 21, 2023 at 8:00 PM
    • #47
    Hello kwakisaki,
    I made a save using the command:
    "Save C://save"
    I was expecting the to find the save in my PC but there's nothing so I guess it was saved in the controller's memory ?
    PS: amp over current on JT5 is back :wallbash:
  • kwakisaki
    694
    4,760
    • February 21, 2023 at 10:29 PM
    • #48
    "Save C://save"
    LOL.......where did you read about how to save using that?
    That file will probably end up in your hidden folders:
    C:\Users\xxxxx\AppData\Local\VirtualStore
    You need to ensure you are using the correct Kawasaki syntax when saving, not just throw in something you think may work.
    You've made me laugh with that save instruction.....Kudos for trying that out though... :hahaha:
    When you put KCWin32 or KRTerm on your PC, where the application is located is the default save area:
    SAVE backup
    If you want to save it to a completely different drive on your PC then:
    SAVE c:backup
    SAVE d:backup
    If you want to save it to a particular folder on a particular drive, you need to create the folder first and make sure it uses the correct Kawasaki syntax.
    SAVE c:file_bups/test_bup
    SAVE d:file_saves/con_bup
  • DoesItExist
    19
    57
    • March 23, 2023 at 6:01 PM
    • #49
    Hello again, it's been a while!
    I was on a holiday then been busy catching up...
    I indeed found it in virtual store (I meant to save in under C:\save but I'm working on a website and switched the syntaxes :pfeif: ).
    Do you need me to upload the save file ?
  • kwakisaki
    694
    4,760
    • March 23, 2023 at 6:32 PM
    • #50
    Now that your in a position that you have a backup, then there is 'little' risk of completely wiping it, making some initial settings and see if the problem remains or resolves it.
    I would be interested to have a look over it though as something in there may just 'jump' out.
    But remember this is a public forum so if there is any IP related data on there you may not want to.
    What is your connection method that you have used to obtain the backup - RS232, PCMCIA, Ethernet?
  • DoesItExist
    19
    57
    • March 28, 2023 at 10:56 AM
    • #51
    I connected the robot with an ethernet crossover cable but I plan on putting it online eventually. Here's the save file with the IP adress removed (I edited the extension to be able to upload it).
    Files
    save.doc 250.28 kB – 12 Downloads
  • kwakisaki
    694
    4,760
    • March 28, 2023 at 11:43 AM
    • #52
    For future reference:
    - 'IP' when referring to data is intellectual property......ie the code, not the IP address.
    - Change the extension of the file save to .txt next time you upload.
    - On old controllers, if you SAVE/IND and then filename, the file data will be tab indented (easier to read).
    Yes, it's full of the ex-jaguar configuration and programs.
    You will need the original if you ever want to restore it back to it's current configuration.
    When carrying out a complete wipe, you will lose ethernet connection but will have RS232 connection, so always better to have RS232 connection available to.
    Up to you if you want to wipe her memory and try a very cold basic setup?
  • DoesItExist
    19
    57
    • December 16, 2023 at 2:51 PM
    • #53
    Hello again everyone,
    I've not updated this thread in a long time so I wanted to give you an update on the situation and the reasons behind my disappearance.
    As I had mentionned In an earlier post, my workshop is rather small and becoming extremely cramped with my machines and tools. I absolutely need to move to a bigger space before I continue expanding.
    Earlier this year, I was expecting to buy a house from a farmer that retired. The house came together with stables, of which I was expecting to transform one into a bigger workshop, move there and enjoy the extra space for expending and specificaly for installing my dear robot friend.
    However, nothing went according to plan. Indeed, a very fortunate man, whose castle overlooks the farm has decided to buy it to prevent anyone from beeing able to alter the beautiful view from his castle's terrace (no I'm not kidding). He met me and my family (we are farmers) and told us he was the one who would get the deal no matter the cost, and if we made him loose money he would make sure to hit back.
    Therefore I had to retract my offer...
    As things stand now, I don't really have any prospect of acquiring a new space for my workshop other than building one. Which would take at least a year to a acquire the permit for plus the time to build it, etc. Therefore I had to put the robot aside as I don't have any space to put it to use in the near future.
    I'd like to thank you all, and specifically give a huge, huge thank you to kwakisaki for his support in this project. Whenever I'm able to find or build a bigger workshop for myself, I'll start working on the robot immediately, as this has been the most fun and rewarding project I've worked on until now (I can't communicate strongly enough the joy of having the remote in hand and the feeling of childish joy it provided me when moving the robot. I felt like a kid playing for the first time with his new toy on christmas day, as well as the awe when seeing the incredible possibilities on kwakisaki's YT channel).
    Sadly this will be it for this thread for a while, I wish you all great end-of-year holidays and I can't wait to start this project again !
  • kwakisaki
    694
    4,760
    • December 18, 2023 at 5:55 PM
    • #54
    I wondered how you were getting on with this, what a shame.
    Seems very under handed and immoral if I am reading it correctly.
    To halt progress of bringing a workhorse back into service due to this is shameful too.
    I hope Santa does not visit him, and if he does, I hope he spits in his eggnog.
    Many thanks for your kind words.
    It is very much appreciated when members reach out with gratitude and it is very well respected too.
    You're very welcome and I hope you can start making progress again real soon........... :beerchug:
  • DoesItExist
    19
    57
    • September 19, 2024 at 3:37 PM
    • #55
    Hello everyone,
    I have good news, i did find a new place for my machine shop ! I now have enough space and just moved the robot in. he is now installed, I also removed the welding cables harness and cleaned it a little. I'll anchor it to the concrete today and I powered it to charge the encoder's batteries. I also had enough room and completely unwound the wires, i noticed there is damage on X3, I re-insulated the wires as i could.
    When I powered the control unit on I had 3 errors that would not clear:
    • 1517 cannot read encoder value jt3
    • 1553 encoder response error jt3
    • 1504 current overload jt5 (this one I expected)
    After a little wait, I cleared the errors and 1504 disappeared while the two others remained.
    Today I came back and had the same two errors that would not clear.
    I'm going to check the cables thoroughly once again and anchor it to the ground. I'll let you know about any further advancement.
    Have a good day everyone !
  • DoesItExist
    19
    57
    • September 27, 2024 at 3:29 PM
    • #56
    Hello everyone!
    Here's my latest update on the state of the robot;
    I've checked the documentation on the errors and it furthered my suspicions of the X3 cable being the cause. I've found someone to check and repair it with me, we'll be on it tomorrow morning.
    I'm also convinced the issue with the encoder is no on the robot harness/encoder side as I swaped the encoders 3 and 4 on the 1FG board (on the robot side directly after the connectors) and still had the errors on jt3...
    On the side, I took a tour of the boards in the controller as it has just been moved and found some plugs that needed a little push.
    Hopefully I'll have a fixed cable tomorrow and no more errors on jt3🤞
    Although this has seemingly nothing to do with the previous jt5 issue, so I'm expecting the error to come back whenever I get the robot moving.
    More news tomorrow, have a good day 😁
    Images
      • 305.47 kB
      • 1,600 × 1,200
      • 6
    Edited once, last by DoesItExist (September 27, 2024 at 3:51 PM).
  • kwakisaki
    694
    4,760
    • September 28, 2024 at 10:54 AM
    • #57
    I would agree as that pretty much proves robot side harnessing without the error swapping over.
    Down to your X3/X3A umbilical/Connectors (pins/sockets) or controller side on the 1GB board or connections to it.
    Regarding JT5 error:
    You may have tight gearing on JT5 and she may just require 'exercising' considering her age so can you jog JT5 in teach mode at all across all or any speed ranges.
    If not you can also do something similar at the motor end for by swapping JT5 and JT6 motor and encoder connections and just test to see if the fault moves (same motors).
    You may need to re-zero JT5 and JT6 but if it is mechanical, then she may need some dinero's and tlc.
  • DoesItExist
    19
    57
    • September 28, 2024 at 1:25 PM
    • #58
    Hello everyone,
    Just had the cable (X3) shortened and took the opportunity to Megger X5, Which had no issues.
    However the errors on the jt3 encoders remain, so I'm starting to suspect a faulty 1GB board.
    I'll try to find and buy another 1GB board and in the meantime check if I can find anything suspicious on the board or between the board and connector.
    As usual I'll let you know how it goes.
    Have a good weekend!
  • kwakisaki
    694
    4,760
    • September 28, 2024 at 1:36 PM
    • #59
    Check CN2 on 1GB board, all encoder signals come from X3 direct and also check inside X3 connector on controller and umbilical connection for damage pins/sockets.
  • DoesItExist
    19
    57
    • September 28, 2024 at 3:14 PM
    • #60
    Hello Kwakisaki glad to hear back from you, I hope you're doing well !
    I did test for continuity with a DVM on all pins of CN2 to the robot side X3 connector and had continuity for the 28 of 39 pins that are soldered to a cable and coherent with the way the cables are wired to X3 inside the controller, the pins on CN2 showed absolutely no damage.
    I also removed the 1GB board and used electrical spray cleaner and pressured air on the board and all it's connectors, plugged it back and had the same issue.
    I retried the encoder swapping, just to be sure and had the same results, so I guess a faulty 1GB is the problem...
  • repair
  • UX150
  • C-type controller
