K-roset load as file error W1008
  • Hello guys,
    I am using RS010N-AN001 robot with F controller. When I try to load an .as file by using Kroset terminal an error appears.
    (W1008) Parameter changed. Turn OFF & ON the control power.
    (W4505) To change the fieldbus parameter, turn the controller power OFF and then ON.
    here are the command lines in terminal
    Any suggestion how can I solve it?
    Cheers
  • Welcome to the forum........... :beerchug:
    Cheers
    For sure, but there are plenty of questions first.
    Have you ever had ANY Kawasaki robot programming training?
    Why are you loading operation, system, aux, interface panel, signal name, storage data in?
    Where did you get the file from that you are trying to load in?
    Are you modifying a previous file save using a text editor and trying to load it in?
    What information are you specifically trying to load in?
