there is not enough memory on the controller to store and run programs Is it possible to somehow run programs from another memory for example compact flash
not enough memory
- A_ghost
- Thread is Unresolved
You didn't mention your controller model.
Usually when people run out of memory they are either using generated code from a CAM software or are not using correct programming techniques. I have done very complex and elaborate programs that were under 200kb.
The controller model is R-30iB plus. The fact is that I have voluminous programs of 10 thousand lines.
There is an option you can purchase for expanded storage. R798 DRAM file storage. I believe that would give you plenty of storage.
Another option would be to setup an FTP server and interface to send files. That option would be much more complicated.
thanks for the information
