I need help with this part of a program. i need to have the cobot go to the start of the program if the part fails. right now if a part fails it rejects and then goes to the next line and continues through the rest of the inspection.
conveyor
MoveJ
Set Laser_Bit_0=Off
Set Laser_Bit_2=Off
Set RH_Trigger=Off
Set LH_Trigger=Off
Above_Conveyor
Waypoint_5
Wait: 0.4
Set LH_Trigger=On
Set RH_Trigger=On
Wait: 1.0
If LH_Laser_Bad or RH_Laser_Bad≟ True
Bef_Above_Bad
Above_Bad_Part
Drop_Bad_Part
Set Vac_1_on=Off
Set Vac_2_On=Off
Above_Bad_Part
Aft_Badpart
Waypoint_1
Set RH_Trigger=Off
Set LH_Trigger=Off
Set Laser_Bit_0=On
Wait: 0.3 Here
Waypoint_6
Wait: 0.6
Set LH_Trigger=On
Set RH_Trigger=On
Wait: 1.0
Bef_Above_Bad
Above_Bad_Part
Drop_Bad_Part
Set Vac_1_on=Off
Set Vac_2_On=Off
Above_Bad_Part
Aft_Badpart
Waypoint_1
MoveL
Drop_Off
Wait: 0.2
Set Vac_1_on=Off
Set Vac_2_On=Off
Wait: 0.2
Above_Conveyor
