Program ABORTED in Auto mode
  • jagroop77
  • January 12, 2023 at 12:32 PM
  • jagroop77
    168
    Hi
    we are facing strange problem in Fanuc Arcmate 100ic R30iB controller.
    When we are running the program in AUTO mode and pressing the emergency button then robot get stop and after reseting the emergency it is not starting from that program line and getiing aborted and go to start point.
    Regards
    Rupy
  • Fabian Munoz
    134
    Articles
    1,517
    • January 12, 2023 at 12:41 PM
    Do you have a PLC connected to it ?
    Maybe when you press the eStop your PLC sends a CSTOP and aborts
    What is your setup on your SYSTEM , Config ? (the first 12 lines )
    Retired but still helping
  • Sergei Troizky
    71
    664
    • January 16, 2023 at 3:22 PM
    Verify the UOP Auto Assignment setup in the System Configuration.
    If it is set to "Simple", the fault reset signal is merged with the program abort.
    FAULT RESET and CSTOPI signals are separate in the "Full" assignment mode.
    Be aware though, that switching to "Full" remaps the UOP signals, which must be reflected in wiring and/or network UOP signals.
  • jagroop77
    168
    • January 19, 2023 at 5:39 PM
    ok I will try the change the UOP Auto setup.
    We are not using any PLC and Just a user panel is used for starting the program.
    Rupy
  • jagroop77
    168
    • February 25, 2023 at 12:27 PM
    HI
    I checked the UOP auto assignment in configuration menu
    It is selected NONE.
    Still the same problem is occuring.
    Whenever we are pressing reset program is getting abort
    Regards
    Rupy
  • DS186
    201
    1,078
    • February 25, 2023 at 12:37 PM
    Quote from jagroop77
    I guess that user panel is connected to the robot controller via discrete wiring?
    Also check the UOP mapping under MENU > I/O > UOP > Config.
  • DS186
    201
    1,078
    • February 25, 2023 at 12:40 PM
    It would be best to provide some pictures of the UOP config screens.
  • jagroop77
    168
    • February 25, 2023 at 7:39 PM
    Dear Please find te UOP Panel wiring diagram and UI config screen
    Please help
    Rupy
    Images
      • 72.5 kB
      • 576 × 1,280
      • 29
      • 71.29 kB
      • 720 × 1,280
      • 31
Similar Threads
  • Background programs
    • SkyeFire
    • October 22, 2020 at 12:36 AM
    • Fanuc Robot Forum
  • How to reset the running program automatically in Ext through PLC?
    • sky12138
    • March 13, 2018 at 3:10 AM
    • KUKA Robot Forum
  • Robot recovery IFWC
    • John11
    • May 11, 2022 at 8:23 PM
    • ABB Robot Forum
  • PROG-050 Aborting still in progress
    • Vlad222
    • October 29, 2021 at 5:27 PM
    • Fanuc Robot Forum
  • Linking a DO to a BG logic run state
    • SkyeFire
    • May 20, 2021 at 7:54 PM
    • Fanuc Robot Forum
  • Issue deleting/editting a PC Program
    • ericwiz7923
    • December 12, 2019 at 5:58 PM
    • Kawasaki Robot Forum
