Looking for a way to combine text and a variable integer for a string in Karel. Tried the following but it will not compile:
VAR
Arg1 : Integer -- This is a variable based on argument value entered when program is called.
String1 : String[32]
String1 = 'UALM', String 1 --DOES NOT COMPILE
String1 = 'UALM' + String1 -- DOES NOT COMPILE
--Trying to utilize result to provide test for
Post_Err(38000, String1, 0 1)
Any ideas if this can be done and if so, what is proper syntax to combine text and integer in string?
