convert an integer to binary KRC
  • ycrideas
  • January 5, 2023 at 4:45 PM
  • ycrideas
    Hi guys!
    I need to convert an integer to binary, it would be something in the code itself, as if it had a DECL I=10 and the corresponding binary of I is returned. I didn't find the solution in the manual and I would like to see with you some possible solution. thanks
    Workvisual
  • Go to Best Answer
  • ycrideas
    • January 5, 2023 at 5:01 PM
    The Binary would be in the form of an array with 16 positions
    ex:
    Number: 3
    Array: F F F F F … F F T T
    panic mode
    1,280
    13,080
    • January 5, 2023 at 5:33 PM
    • Best Answer
    then just write your own... assuming this is 16-bit
    DEF DECODE16(val1:in, val2[]:out)
      DECL INT val1, i, n
      DECL BOOL val2[]
      i=1
      FOR n=1 to 16
         val2[n]=(val1 B_AND i)<>0
         i=i+i
      ENDFOR
    END
    DEFFCT INT ENCODE16(val1[]:out)
      DECL BOOL val1[]
      DECL INT i, n, tmp
      tmp=0
      i=1
      FOR n=1 to 16
          IF Val1[n]==TRUE THEN
              tmp=tmp+i
          ENDIF
          i=i+i
      ENDFOR
      RETURN tmp
    ENDFCT
    then you could use them to do something like
    DECL BOOL BitNumber[16]
    DECL INT MyValue1, MyValue2
    MyValue1 = 10
    DECODE16(MyValue1,BitNumber[])
    ; and the other way
    BitNumber[1]=TRUE
    BitNumber[2]=FALSE
    BitNumber[5]=TRUE
    MyValue2 = ENCODE16(BitNumber[])
  • ycrideas
    • January 5, 2023 at 5:47 PM
    thanks panic mode
  • ycrideas
    • January 11, 2023 at 2:58 PM
    morning, I managed to convert the integer, but the values that are filled in the array are the other way around, could you help me?
    in this case there will always be 16 array positions, but only the first ones will actually be used
    another thing man, I didn't quite understand what this ENCODE16 function does, can you explain? thank you so much
    Edited 2 times, last by ycrideas (January 11, 2023 at 3:32 PM).
    panic mode
    1,280
    13,080
    • January 11, 2023 at 8:42 PM
    Quote from ycrideas
    Just reverse index...
    N goes through values 1..16 so to get 16..1 replace N with 17-N:
    val2[17-n]=(val1 B_AND i)<>0
    ENCODE16 is inverse of DECODE16. It does exactly the opposite...
  • ycrideas
    • January 13, 2023 at 12:25 PM
    hi, I have a big problem,
    in this case it doesn't work as expected, in fact the array will be inverted, but it must be taken into account that several integers will not occupy the 16 positions of the array.
    for example the number 42 would be (0000000000010101) and in fact it should be (1010100000000000).
    when I use val2[n]=(val1 B_AND i)<>0 the expected array would be 1010100000000000 and it returns 0101010000000000, that is, the actually occupied positions are inverted
  • hermann
    407
    2,611
    • January 13, 2023 at 12:37 PM
    42 binary is:
    0010 1010
    Your assumption 0001 0101 is wrong. You can see it on one sight. Lowest bit must be zero, as 42 is an even number.
    panic mode
    1,280
    13,080
    • January 13, 2023 at 5:16 PM
    Quote from ycrideas
    ...it returns 0101010000000000
    42 is 0000000000101010 but you wanted bit array reversed. so program returns correct output.
Similar Threads
  • How to receive integers frpm PLC to a KR10 R1420 KRC4 V8.3
    • Doe
    • June 27, 2019 at 3:02 PM
    • KUKA Robot Forum
  • convert int to binary
