Errors Adding External Axis to 5.5.12
  • jesusvaricap
  • December 21, 2022 at 4:31 AM
  • jesusvaricap
    259
    Hello ,
    Im trying to add an external axis to the robot KR16_2 C2 # article 11010711 with cabinet (V)KRC2 ed05 # article 11010711 KSS 5.5.12
    With motor # article 69-225-463 and KSD1-32 # article 00-122-286
    in the past i configured the same motor and KSD32 with KSS 5.2.14 KR2210L150S2000 with no problems
    attached madas
    Now , i configure my MADA for 5.5.12 with the data before used on KSS5.2.14 and appears errors:
    436 short circuit braking request by RDC1
    114 difference between XML /RDC data and machine data
    1008 Dynamic model does not support this robroot kinematic
    DYN_DAT [422] ,DYN_DAT [492] DYN_DAT [496] on MADA
    i try with other servo files , cold start and its not possible to add external axis on KSS5.5.12
    I take a new HDD install operating system and KSS 5.5.16 , 5.5.10 ,5.6.12 and was not possible to install KSS , apparently KR16_2 C2 # article 11010711 with cabinet (V)KRC2 ed05 # article 11010711 only works with KSS 5.5.12 , so i take again my HDD with 5.5.12 and still trying to add external axis.
    Any idea to add my motor and KSD ?
    im not using SMB2 , im using X17 and X12 from the KPS
    Kind regards
    Files
    MADA 5.5.12.zip 41.62 kB – 13 Downloads mada_KSS5.2.14.zip 30.43 kB – 7 Downloads
  • Fubini
    277
    1,884
    • December 21, 2022 at 5:12 AM
    How exactly did you transfer the machine data?
    If I remember correctly 114 refers to absolute accuracy. The pid file is stored on rdc and contains the machine data it was created with. When the system starts up machine data in the pid file is compared to the standard machine data. If both sets do not match this message is generated. To verify you could temporarily deactivate absolute accuracy and see if the message vanishes. My theory would be you accidentally have overwritten the rdc on the 5.5 with the data of the rdc of the 5.2 robot.
    Furthermore there is also a shadow copy of $robcor.dat in rdc that could cause 1008 for similar reasons. This also indicates rdc data is somehow different to other data. You could compare $robtrafo (robot type of machine data stored on rdc) and $trafoname ( robot type in conventional machine data) to see if they match.
    These type of data mismatch usually needed to be resolved by either pushing the correct data to the rdc or pulling the correct from rdc. Which action is the correct one depends on which data is the correct one. The push or pull can be done inside the robot data hmi menue.
    Fubini
  • panic mode
    1,278
    13,076
    • December 21, 2022 at 3:23 PM
    comparing MADA of two different robots and from different KSS versions will produce too much "noise".
    the simple way to tell what parameters need to be changed is to compare MADA.
    the best way is to compare two MADA that are for the same KSS and the same robot type - even if that is not the robot type you are planning on using (because MADA collection for your KSS may not have both versions for your robot). so just choose one with robot alone and the other for same robot but with linear rail for example. all of this should be on D:\
    this will give you a very clean list of things that need to be manipulated when adding external axis.
  • jesusvaricap
    259
    • December 24, 2022 at 2:24 AM
    Fubini
    im doing changes of mada with software "winmerge " i edit macnine.dat ,$robcor.dat according [7] data axis
    inhibiting kss starup , pressing key CTrl i replace $macnine.dat robcor.dat
    also with a backup i modify $machine .dat,$robcor.dat and restore then cold start and its not possible to add external axis correctly.
    panic mode
    Good idea! i compare the machine data of kr210 with KL500
    with KR16_2 empty , i configure according [7] data axis and still with problems:
    108 safety state of rdc not confirmed
    also appear DYN_DAT erros
    Appears E1 need to be adjusted , i asume the external axis was added but not correctly.
    unfortunatly on D:/ theres not KSS 5.5.12 to re-install kss only there is folder MADA and OPT.
  • Fubini
    277
    1,884
    • December 24, 2022 at 6:11 AM
    $robcor.dat does not need any modifications when adding an external axis. Especially not the dyndats.
    With how exactly I meant not thprocedure but the data you changed. You should change them back to their original values.
    You say according to [7]. What's [7]?
    Fubini
  • jesusvaricap
    259
    • December 24, 2022 at 6:55 AM
    Sorry not robcor.dat i modify, i modify machine.dat on the area according to external axis [7]
    $RAT_MOT_AX[7]=
    $RAT_MOT_ENC[7]=
    $DSECHANNEL[7]=
    Etc
  • panic mode
    1,278
    13,076
    • December 25, 2022 at 4:02 AM
    in first post you shared MADA from two different robots on two different KSS versions. This is bound to produce a lot of differences which is not what you want.
    This is why i suggested comparing MADA on same KSS and for same robot, so that the ONLY difference is the external axis... That compare will produce only a handful of differences and that would make it very clear WHICH values need to be modified when adding external axis.
  • jesusvaricap
    259
    • January 3, 2023 at 12:29 AM
    i still tryng to add the external axis....
    my robot have safeRDC, its neccesary an aditional config ?
  • panic mode
    1,278
    13,076
    • January 3, 2023 at 1:08 AM
    no
  • panic mode
    1,278
    13,076
    • January 3, 2023 at 1:52 AM
    Quote from jesusvaricap
    i checked Parts and Docs for KRC2. it turns out this motor is used on KL1000, KL1500 etc.
    btw. this one is also known as type B motor.
    next i did exactly as mentioned before, went through MADA on ImageD.wim from one of KRC2 backups, picked MADA for robot KR2210 standalone as well as MADA for that same robot mounted on the rail, then compared their $MACHINE.DAT files. all things that are different boil down to following:
    $AXIS_TYPE[7]=1 ; linear axis
    $RAT_MOT_AX[7]={N -35526926,D 1000000} ; gearing transfer ratio is -35.526926:1
    $RAT_MOT_ENC[7]={N 1,D 4} ; resolver and motor are 4-pole
    $DSECHANNEL[7]=7 ; DSE channel
    $PMCHANNEL[7]=21 ; brake is on KSP600 X12 (no SBM)
    $SERVOFILE7[]="KSD_48_MK_S7_0" ; name of *.servo file used
    $CURR_MAX[7]=32.0 ; maximum motor current
    $CURR_MON[7]=17.5
    $KT_MOT[7]=1.35
    $KT0_MOT[7]=1.42
    $RAISE_TIME[7]=850.0
    $RAISE_T_MOT[7]=6.8
    $VEL_AXIS_MA[7]=4000.0 ; motor can go up to 4000RPM
    $RED_VEL_AXC[7]=7
    $RED_ACC_AXC[7]=15
    $RED_ACC_OV[7]=100
    $RED_ACC_EMX[7]=210
    $VEL_AX_JUS[7]=0.25
    $L_EMT_MAX[7]=9.6
    $LG_PTP[7]=0.75
    $LG_CP[7]=0.75
    $DECEL_MB[7]=404.0
    $G_COE_CUR[7]=15
    $G_VEL_PTP[7]=80.0
    $G_VEL_CP[7]=75.0
    $I_VEL_PTP[7]=900.0
    $I_VEL_CP[7]=200.0
    $APO_DIS_PTP[7]=500.0
    $IN_POS_MA[7]=1.5; use large in-position value (1.5mm) for a linear axis
    $SOFTN_END[7]=-10000.0
    $SOFTP_END[7]=10000.0
    $INC_EXTAX[1]=0.006
    INT $EX_AX_NUM=1 ; total number of all external axes (0-6)
    DECL EX_KIN $EX_KIN={ET1 #ERSYS,ET2 #NONE,ET3 #NONE,ET4 #NONE,ET5 #NONE,ET6 #NONE} ;EXTERNE KINEMATIKEN #NONE, #EASYS,#EBSYS,#ECSYS,#EDSYS,#EESYS,#EFSYS,#ERSYS
    DECL ET_AX $ET1_AX={TR_A1 #E1,TR_A2 #NONE,TR_A3 #NONE} ;EXTERNE ACHSEN #NONE, #E1, #E2, #E3, #E4, #E5, #E6
    $ET1_NAME[]="KL1500_3_2000_32_12" ; name of the kinematic
    FRAME $ET1_TA1KR={X 0.0,Y 0.0,Z 450.0,A 0.0,B 90.0,C 0.0} ;frame between A1 and root point of the kinematic in transform ET 1
    FRAME $ET1_TFLA3={X 0.0,Y 0.0,Z 0.0,A 0.0,B -90.0,C 0.0} ; frame between Flange and A3
    $AXIS_JERK[7]=8.02851472
  • jesusvaricap
    259
    • January 7, 2023 at 2:57 AM
    • #11
    Thanks for the info ,
    yes , the data that i change its accoriding you write for me.
    any changes i do with Mada and then after start cold appears the next errors :
    114 SRM Difference between XML / RDC data and machine data
    108 SRM safety state of the RDC not confirmed
    436 Short circuit braking request by RDC 1
    441 Invalid configuration on SafeRDW
  • panic mode
    1,278
    13,076
    • January 7, 2023 at 3:16 AM
    • #12
    you have a safety robot. when hardware configuration changes, new safety configuration need to be acknowledged. in this case there was such change - new axis is added.
  • jesusvaricap
    259
    • January 13, 2023 at 2:01 AM
    • #13
    ok , checking my wiring of X40 C4 and C6 arent jumpered with A9,A11,B2 also C3 and C5 arent jumpered with A10,A12,B1
    what indicates or what function are habilited on my actual config ?
    if i do the wiring like the next post :
    Thread
    KRC2 - X11 & X40
    use at own risk....
    panic mode
    August 19, 2016 at 6:09 PM
    what indicates or what function are habilited ?
  • jesusvaricap
    259
    • January 21, 2023 at 2:10 AM
    • #14
    i do the wiring X40 according the post Manuals, Software and Tools for KUKA Robots
    modify mada , cold start , and the next messages appears :
  • Fubini
    277
    1,884
    • January 21, 2023 at 4:49 AM
    • #15
    Quote from panic mode
    See above. Did you acknowledge the safety configuration?
    Fubini
  • jesusvaricap
    259
    • January 21, 2023 at 4:51 AM
    • #16
    No , any messages about safety configuration
  • hermann
    406
    2,607
    • January 21, 2023 at 8:46 AM
    • #17
    This IS a message about safety configuration.
  • jesusvaricap
    259
    • January 23, 2023 at 3:20 PM
    • #18
    I haven't X11, i only have jumpered directly from the CI3 board on X22 attached pictures
    It's necessary jumper some cables to add external axis?
    Or what it's necessary to do for add external axis?
    Images
      • 210.15 kB
      • 1,920 × 864
      • 8
      • 265.55 kB
      • 1,920 × 864
      • 5
      • 306.42 kB
      • 1,920 × 864
      • 6
  • panic mode
    1,278
    13,076
    • January 23, 2023 at 5:03 PM
    • #19
    first you need to understand the architecture and what the message is telling you.
    X11 interface is used for basic safety only. But this seem to be what you are focusing on.
    SafeRDW is at the base of the robot and has additional safety IO and settings Settings are parametrized in your SafeRDW plugin (accessible through HMI). Those safety IO are on X40 and also will need to be wired. This is the part you are neglecting even though that is exactly what message is telling you to do. You need to read the documentation for your SafeOperation version and configure it according to your setup and needs.
  • panic mode
    1,278
    13,076
    • January 23, 2023 at 5:25 PM
    • #20
    btw, check READ FIRST topic.
    you did not state SafeOperation version, what settings are used currently etc.
    hope you realize that people trying to help you do not have spare KRC2 with SafeRDW to look things up or try them out.
  • ed05
  • 5.2.14
  • 5.5.12
  • 11010711
  • 69-225-463
  • 00-122-286
  • 436
  • short circuit braking request
  • 114
  • difference between XML /RDC da
  • 1008
  • Dynamic model does not support
  • DYN_DAT
