Need Help with Mastering
  • Victortz88
  • December 14, 2022 at 5:44 PM
  • Victortz88
    8
    I changed a DCS setting and on the next power up i had a quick mastering for group 1 not set. I followed the procedure and did a set quick Master Ref . When i check the DCS Mastering parameters, the master count numbers are correct. But no position is correct. I been scrolling through the menus and see set up and ref postion. I am new to mastering and want to know what the process is . I have the old program in roboguide. would uploading the backup fix this?
    Images
      • 76.6 kB
      • 681 × 754
      • 18
  • R47
    110
    • December 15, 2022 at 7:33 AM
    hi Victorz88,
    try to load the SYSMAST.VA file in Controlled start.. may that helps you out.
  • Victortz88
    8
    • December 15, 2022 at 1:44 PM
    R47 I tried that and didn’t seem to work . I then tried to do a whole back up by uploading all the files but now I believe the features were not uploaded . With robo guide don’t think I can create image files . Is there a way to back it up using the dt file ? When I uploaded all the files it has a different start program on start up . But when I create a new cell with the dt file it works .
  • HawkME
    568
    3,268
    • December 15, 2022 at 2:26 PM
    backdate.dt is only for roboguide.
    Roboguide is not used at all for backup or restore of a robot.
    Did you ever take an image backup on your real robot?
    Did you ever take an all of the above file backup from your real robot?
    After changing the quick mattering did you apply the DCS changes and enter the password?
    What do you mean features are missing? That doesn't make sense.
  • Victortz88
    8
    • December 15, 2022 at 3:19 PM
    I was referring to the paid features HawkME but i was incorrect and on the second attempt it all is loaded correctly now. Thanks for the help. Currently have a IRPK-217 Invalid Robot ID and no information online as to which menu it is located so that i can change it. Any help with that? Thanks
  • HawkME
    568
    3,268
    • December 15, 2022 at 7:20 PM
    The only Robot ID found is in a system variable. Hopefully that is it.
    Go to Menu>System>Variables. Scroll down to $SCR_GRP, then press enter. Then scroll down to $ROBOT_ID. It should be the model of your robot.
    For example: M-10iA/12
Similar Threads
  • Effect of mastering on high precision application
    • tyh0921
    • November 22, 2021 at 3:46 AM
    • Fanuc Robot Forum
  • Search [X], [-X], [Y], [-Y], [Z], [-Z], Simply task a lot of Obstacles
    • fmiroslav
    • May 13, 2021 at 9:18 AM
    • Fanuc Robot Forum
  • Safe Operation Mastering test issue
    • Marvin_PA
    • September 24, 2020 at 5:33 PM
    • KUKA Robot Forum
  • PLAL BUT BATTERY MEASURES 3.1 Vdc BZAL servo 62
    • Tsocmh
    • November 12, 2019 at 5:43 AM
    • Fanuc Robot Forum
  • krc2 automatic mode problem and position loss problem
    • bishoy naguib
    • May 18, 2019 at 4:15 PM
    • KUKA Robot Forum
  • S-10 Motor Overheat
    • droth
    • March 29, 2019 at 12:46 PM
    • Fanuc Robot Forum
  • About to receive my first KUKA robot... setup preparations.
    • Koppel
    • February 13, 2019 at 9:16 PM
    • KUKA Robot Forum
  • KRC1 Mastering trouble
    • schelle
    • November 7, 2018 at 4:14 PM
    • KUKA Robot Forum
  • mastering
  • quick mastering
  • Calibrating
