Background edit 4, cant end edit
  • was using remote ipandent to do background edit. since it was remote the program was being edited in BCKED4. when i go to end_edit i dont get the pop-up that you normally get asking if you want to discard or accept the changes. BCKED4 doesnt actually end that program and its not possible to select another program.
    any suggestions?
  • Where do you "go to end_edit"? On Remote iPendant?
    - Are you able to do anything else on remote iPendant?
    iPendant may be locked in SETUP>>Host Comm>>HTTP Authentication.
    - In SELECT>>Program DETAIL, ensure the program is not write-protected.
    - Check the system variables in #UI_CONFIG.$READONLY. All three must be FALSE.
  • seems like i am able to do everything else through Remote iPendant
    checked the HTTP Authentication and its all good there
    the program is not wtire-protected, so its good on that side
    and #UI_CONFIG.$READONLY all three are false.
    im thinking maybe the pop up is getting blocked? or i am not able to see it? when i click End_edit the iPendant becomes unresponsive for a few seconds (30 or so) and than nothing else happens
  • thanks HawkME that worked, unfortunately i hit enter too many times and it selected GETDATA as the background edit and now when i try End_edit it gives two different errors:
    TPIF-054 could not end editing
    TPIF-008 Memory Protect violation
    i tried going into GETDATA program and changing Write Protect to off but it doesn't let me
  • You need to press end edit the click the arrow button over to select discard changes. Then press enter.
    It's easier to do if you can test on a different working system to get the sequence down correctly so you can do it blind.
