Setting a program as main program
  • GoodFellas41
  • December 13, 2022 at 10:04 AM
  • GoodFellas41
    23
    Hi guys,
    I'm working with R-30iB mate plus Fanuc robot. I already have couple of programs. I'd like to select specified program from the program list. I'd like to run that specified program each time I press the start button. Is this possible?
    Thank you!
  • Fabian Munoz
    133
    Articles
    1,517
    • December 13, 2022 at 1:14 PM
    Hi
    This is the key sequence.
    MENU, SETUP, Prog Select, OTHER, DETAIL, CHOICE
    Retired but still helping
  • GoodFellas41
    23
    • December 13, 2022 at 1:33 PM
    Thanks for your answer,
    When i follow the path, MENU, SETUP, Prog Select, there is no button named OTHER. I'm just a newbie at programing a robot. so could you please be more spesific?
    I just got that I need to learn how to external start. I found the UI[6] START signal. All I need is run a spesific program from the program list with a button. How can I connect a button to UI[6] START signal that would start a spesific program from the program list?
  • GoodFellas41
    23
    • December 13, 2022 at 1:54 PM
    Quote from Fabian Munoz
    Hi
    Hello Fabian Munoz,
    The true path is MENU, SETUP, Prog Select, Choice, Other.
    I set it as OTHER and chose the desired program. But I still dont know how can I use it. Cuz when I start automatically the robot another program started to run. Is this an error and how can I fix it?
    Thanks a lot
  • Fabian Munoz
    133
    Articles
    1,517
    • December 13, 2022 at 2:14 PM
    On the screen that you see the option OTHER, What do you have for Production start method. You should have UOP and you should start the program with UI6 Start
  • GoodFellas41
    23
    • December 13, 2022 at 2:21 PM
    What do you mean with start it with UI6 ?
    I'd like to start it with a button, when I press that button I want to run the desired program from the program list.
  • Fabian Munoz
    133
    Articles
    1,517
    • December 13, 2022 at 2:37 PM
    Let me try on my robot and try yo see what you are missing
  • Fabian Munoz
    133
    Articles
    1,517
    • December 13, 2022 at 3:44 PM
    The problem is that to be able to use OTHER you have to use UI
    Search forum for $shell_wrk.$cust_name
Similar Threads
  • Overarching Movement Variables
    • Birch8101
    • September 30, 2022 at 1:27 PM
    • KUKA Robot Forum
  • Beginner questions
    • robotecnik
    • July 7, 2022 at 12:31 PM
    • Fanuc Robot Forum
  • stack overflow error
    • chris051873
    • January 14, 2019 at 4:23 PM
    • Fanuc Robot Forum
  • How to get back to Main
    • bbishop108
    • January 22, 2020 at 7:55 PM
    • Fanuc Robot Forum
  • DRIVE 6, degs-ma[5],50
    • robotik
    • January 8, 2020 at 1:21 PM
    • Kawasaki Robot Forum
    • TSGIR
    • June 30, 2019 at 1:49 PM
  • Motion Interlock FANUC
    • a00948630
    • June 19, 2019 at 7:59 PM
    • Fanuc Robot Forum
  • Weirdness
    • droth
    • February 13, 2019 at 9:31 PM
    • Fanuc Robot Forum
