Use USB Stick and KUKA HMI on KCP.
one option is to use archive
but for individual programs, the simplest and fastest way is to do as hermann suggested:
1. login as expert (so other drives can be seen on HMI)
2. connect USB stick
3. use HMI to copy/paste files to/from USB stick
instead of USB stick you can also use Ethernet. just share folder on D:\ so you can access it remotely and still use HMI to transfer to/from KRC and that folder
