Is there a way to read current kuka user level?
  • bootsch
  • December 8, 2022 at 12:07 PM
  • bootsch
    Currently working on a KR C4, KSS V8.6.7.353.
    Is there a way to get the current user level (operator to expert) from a system variable? (I could not find it in any of the 'system variables' manuals)
    I have the need to provide this info to the HMI through a PLC.
    Fubini
    272
    1,872
    • December 8, 2022 at 12:26 PM
    • Best Answer
    $USER_LEVEL
    Fubini
  • bootsch
    • December 8, 2022 at 12:40 PM
    Thanks Fubini!
    I thought I remembered there was something...
    I can see the value with display -> variable -> single
    To add, it is not mentioned in any of the system variables or the system integrator manuals and does not show up in a full project search in WorkVisual.
    Thanks again!
  • panic mode
    1,267
    13,033
    • December 8, 2022 at 2:14 PM
    Quote from bootsch
    Quote from bootsch
    that is incorrect... all you needed to do is use manuals for your KSS version. are you sure you are using correct manuals?
    Btw this was added in KSS 8.5 and this is documented in system variable manuals for KSS 8.5 and 8.6:
  • bootsch
    • December 8, 2022 at 3:05 PM
    Quote from panic mode
    I stand corrected... used incorrect kss version manual.
    :uglyhammer2:
  • IO
