WorkVisual System Variable Errors
  • $STOPMESS==TRUE
    $H_POS=XHOME
    $VEL_AXIS[1] = SVEL_JOINT(100.0),
    $TOOL = STOOL2(FHOME), $BASE = SBASE(FHOME.BASE_NO),
    $IPO_MODE = SIPO_MODE(FHOME.IPO_FRAME),
    $LOAD = SLOAD(FHOME.TOOL_NO),
    $ACC_AXIS[1] = SACC_JOINT(PDEFAULT),
    $APO = SAPO_PTP(PDEFAULT),
    $GEAR_JERK[1] = SGEAR_JERK(PDEFAULT),
    $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
    I created the new project in Workvisual
    I also added controller components in the controller(KRC4) and Manipulator(KR 16 L6-2 C)
    1. Cabinet Interface Board (CIB)
    2. CIB Safety Module (SION-CIB)
    3. Resistor (1.6 KW)
    4. KUKA Power Pack 3 20A (KPP3)
    5. KUKA Servo Pack 20A (KSP)
    6. EMD
    7. Safety Interface Board SIB Standard (SION-SIB-STD)
    8. 7. Safety Interface Board SIB Extended (SION-SIB-EXT)
    and then generate code is applied but still shows above mentioned variables are showing RED
    WHY
    I attached the Workvisual photos
    give me an appropriate solution
    HELP !!!!!!
  • These are defined in bas.src. Where does your bas.src come from? Is it even part of your project and if yes does it have the necessary declarations?
    Fubini
    Actually, I created the KRC4 Project from the very initial stage mean didn't browse the project from
    KUKA robot
    I considered as there is no robot present.
    and I assigned the all CONTROLLER component in that way
  • and that is the problem...
    creating project from scratch creates a skeleton with some meat on it but - such project is still not complete. more things exist on the controller that are still missing in your project. this means you need to add them manually or do a merge with controller. until this is done you will see things like that.
