KAREL abort all is blocked by program that needs to be aborted
  • I need to be able to run a KAREL program continuously in the background, that listens for a KAREL variable (or perhaps we will look into using a flag for this) that signifies an abort all request. Using a background logic program would be perfect, but KAREL programs sadly cannot be used here. I have tried to use a hot start autoexec program that calls a 'listener' KAREL program with the infinite loop, however this autoexec program still blocks the execution of other KAREL/TP programs which we need for the robot's regular functionality (TPIF-013 Other program is running). I am not sure what other options I have to implement this functionality, all options seems to get stuck on the fact that a program that is running and needs to be aborted blocks the execution of the abort_all program... Any suggestions would be appreciated.
  • Place your Ad here!
    • Helpful
    The parent would stick around, which is probably what you call blocking.
    According to the manual:
    If you want the child task to be completely independent of the parent, a KAREL program can initiate
    another task using the KCL or KCL_NOWAIT built-ins to issue a KCL>RUN command
  • a KAREL program can initiate another task using the KCL or KCL_NOWAIT built-ins to issue a KCL>RUN command
    You are correct, this seems to be what I'm looking for. However, I can't seem to get a KCL call in the KAREL script right. When I'm trying to call a sample KAREL-program 'hello_world.pc' I get status results unequal to 0.
    KCL('LOAD PROG hello_world', status) -> returns 2014
    KCL('RUN hello_world', status) -> returns 24003 (probably because it wasn't loaded correctly)
    Now I can't find any help regarding these return values online, so I'm still stuck.
  • When I'm trying to call a sample KAREL-program 'hello_world.pc' I get status results unequal to 0.
    2014 is file-014 which is "file not found".
    According to the manual again:
    Purpose: Loads a p-code file from the default storage device and default directory into memory using
    the specified or default file name. The file type is assumed to be ``.PC.''
    If file_spec is not specified, the default program is used. If the default has not been set, then the
    message, ``Default program name not set,'' will be displayed.
    Note For R-30iB Plus, R-30iB, and R-30iB Mate controllers, the KAREL option must be
    installed on the robot controller in order to load KAREL programs.
  • Have you seen this thread:
  • 2014 is file-014 which is "file not found".
    Is there any error code conversion table available? I have tried looking for it but could not find it online.
    Regarding the use of the load function; when I already have the .PC file in the controller's memory (but not loaded as the active program), do I need to load the file before I can run it using RUN?
    Yes I have found this, but the issue in that thread is not what I am running into. I can run a KAREL program as a hot_start program without issues, the problem arises when I want to call another program from this hot_start-ed program.
    What is your $SCR.$MAXNUMTASK variable? Maybe increasing this variable and using autoexec will solve your problem.
  • The maximum number of user programs which can be run simultaneously. You can change it in controlled start. I had similar problem and it helped me, but if your variable is set to 4 maybe its not the problem. What does your code look like?
  • The auto-exec program is as follows:
    And the program 'test_bg' that I try to call is for now a simple program I use to debug the functionality:
    Both programs build successfully and their .pc files are in the controller's memory in roboguide.
  • Easy solution: don't call a different program. Why don't you start the 'test_bg' direct by autostart.
    And by the way: it's a good idea to change the WHILE TRUE with a test for a flag or something else to be able to stop the background program. Otherwise testing will be a bit fiddly.
  • Yes I have found this, but the issue in that thread is not what I am running into. I can run a KAREL program as a hot_start program without issues, the problem arises when I want to call another program from this hot_start-ed program.
    In that thread there is described a solution with assigning a macro to a flag, and start the macro by setting this flag, this works with starting TP or Karel programs from a autostart routine, and the foreground task is not blocked by those background tasks.
