What's problem?
Emergency stop inoperative
- Jigu
- Thread is Unresolved
The problem is the lack of information from your side. Please read forum ReadFirst and then try again.
Fubini
What kind of information do you need?
Minimal requirements can be found in ReadFirst. Asking us what we need is a bit difficult. This would require us to read your mind. The more info you can provide about what you did how your system is configured and stuff like that helps.
Also think about what else you could share? Only you can for example know the history that lead to this error. You are the only one who can tell what type of safety you are using ...
And postin screenshots in Chinese not helpful at all. Can you switch to English before posting them?
Fubini
Okay l. I read Readfirst. But it's not Chinese, it's Korean.
Sorry for that my bad.
He asked for switching to English (so chinese or korean does not really matters)
your HMI allows changing language and this is a very quick operation that does not require restart etc. since posting in English forum it is expected that all posts (and screenshots, code samples etc.) are in English.
The screen indicates that there is a problem with safety configuration. message literally says "safety has problem". so guess what info would be useful? hint - it is not the board temperature.
it would be good to see all 5 messages, KSS version (on the KRC and in the WoV project), anything related to system configuration. if the WoV project is for wrong hardware or using wrong topology, KSS would not know what to do with it. And the first thing it would complain about is the hardware/safety. and you mentioned none of this... hence the suggestion to read pinned topic READ FIRST
