ROBOT : KUKA KR10R1100_2
KSS 8.6.9 HF2
Kernel system version KS V8.6.52463
Is it possible to install KSS V8.3 (downgrade) on a robot that has version KSS V8.6 ? In case yes what is the procedure?
KSS 8.6.9 HF2
why in the world would you want to do that? if anything one should look forward to upgrade software.
at any rate, there are different MCCs and this determines KSS compatibility. so for this you need to contact KUKA. and that is also the only legal way to upgrade/downgrade software versions and get new licenses.
Hi panic mode
we have a problem with the installation of the new RSI package - that is, the new version of the RSI package does not correspond to the additional software that uses this communication (OnRobot has not developed a software version for the new version of RSI)
Hi panic mode
thank you on you fast response, one more question:
we have agilus KR 3 R540 with KSS 8.3, and new KR10 R1100 with KSS 8.6 is it possible to switch controllers and change RDC data?
KSS 8.6.9 HF2
No You can't
8.6.X software running on new motherboard and 8.3 not supported. Also vice versa not supported.
Hi panic mode
But this is an interesting question! Does anyone know if this solution can work?
