  4. Stäubli & Bosch Robot Forum
How to get the actual TCP with HERE instruction
  • danielangos
  • November 29, 2022 at 4:32 PM
  • danielangos
    14
    HI!
    I am trying to get the actual TCP of the robot , i saw that the instruction HERE returns the position but i am having problems using it , my question is , with what data type do i have to use it?
    I was trying to move the value to a pointrx but it says there is an error , i have also tryed with trsf data type but i guess i am doing something wrong.
    Thanks ina dvance!!
  • Galet
    19
    141
    • November 29, 2022 at 4:51 PM
    pActualTcp=here(tTaladrato,fDrilling)
    Your line is correct if
    pActualTcp is a PointRx (6axes robot) or a PontRs (4axes robot)
    tTaladrato is a Tool
    and fDrilling is a frame.
    But here() return a cartesian position, not the actual Tcp (tool)
    What the error message ?
    Best regards,
  • danielangos
    14
    • November 29, 2022 at 4:56 PM
    Hi!
    I run the program in the robot and i get a ERR70
    Yes , i want the the cartesian position between the fdrilling which is a frame and the ttaladrado which is a tool
  • Galet
    19
    141
    • November 30, 2022 at 9:15 AM
    ERR70 :Invalid instruction parameter. See the corresponding instruction.
    In manuel mode, it is possible to select the Frame, and the Tool, and learn the point ?
    If it's Ok, can you show us the program (2 or 3 lines before and after this line) ?
    Control the message in the logger.
    Best regards,
  • danielangos
    14
    • December 1, 2022 at 4:33 PM
    Thanks for your help Galet!!
    It turns out that i was introducing wrong parameters to the frame data and that was the actual error instead of the here
Similar Threads
  • Error E6007
    • DChernyshev
    • September 23, 2020 at 7:12 PM
    • Kawasaki Robot Forum
