  4. Stäubli & Bosch Robot Forum
Staubli How to pass from float to 4 Bytes and viceversa
  • danielangos
  • November 28, 2022 at 11:21 AM
  • danielangos
    14
    Hi!
    I am working with a Staubli CS9 controller which is a profinet slave of a Siemens 1500CPU , i am trying to send and receeive floats values between both.
    I already have the profinet net working, the CS9 is configured to have 128 bytes input and 128 bytes output trough the j207/208 ports , the things is that in the PLC i want to have floats instead of bytes , i already have the gsdml xml archive with the corresponding inputs/outputs.
    But, how do i turn from 4 bytes to a float and viceversa so i can use real numbers and not hexadeciamal between 0-255 values?
    Thanks in advance!!!
  • kwakisaki November 28, 2022 at 2:16 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Stäubli & Bosch Robot Forum.
  • Galet
    19
    141
    • November 28, 2022 at 2:48 PM
    You need SRS to configure the robot fieldbus.
    You can edit the configuration of the board with Sycon and change the repartition between all the signals (change each 64 bytes modules from Bytes to Signed32).
    Be careful because Sycon is always looking from Master part.
    After change, you can create the new Gsdml file.
    BRegards
  • danielangos
    14
    • November 28, 2022 at 3:43 PM
    Hi! , thanks for the help
    I only get these options , how do i change to the signed 32?
  • Galet
    19
    141
    • November 28, 2022 at 4:17 PM
    In your picture, after "Modules" you see "Signal Configuration"
    Click on it to edit and define the type of all signals and choise Signed32...
    Best regards
  • danielangos
    14
    • November 28, 2022 at 5:04 PM
    Thank you very much!!
