Tpsi500_kr10_ethercat
  • Dear all
    I was trying to communicate Fronius tpsi 500 with my KR10 robot via Ethercat protocol
    After configuring Fronius standard image into work visual I am getting the following error
    1. Fronius Fb inside EtherCAT stand is not connected to the bus
    So after this, I connected Fronius to ek1100 but it started to show the following error
    1. Error during EtherCAT initialization
    Robot: KR10
    Cabinet: KRC4 COMPACT with iocard
    KSS: 8.6.8
    Please do advice me on this
  • are you sure the Fronius I/Os are correct size?
    are you sure things are connected correctly?
    did you check bus topology and compare it with physical connections?
