Overall Goal:
- Commission cell for robotic milling in my wood shop. If you are interested to see what type of work I do, check it out here.
Hardware and Software:
- Controller: KRC4 8.2.28 (purchased second hand from Mercedes with unique safety setup using Profinet 2.2)
- Robot: KR 210 R 3100 Ultra floor (Purchased second hand separately from controller.)
- PLC: S7 1212 FC DC/DC/DC
- Software: Work Visual 6, STEP 7 Basic TIA Portal V17 with Safety Basic
Reference Documents:
- KRC4 PROFINET 2.2 (Page 14, Section 5.3, "Making GSDML files available for configuring with WorkVisual") Link to document
- KUKA.SafeOperation 3.1 (Currently studying) Link to document
Specific Goal For Questions Below:
- Configure Siemens S7 1212FC PLC as Profisafe device in WorkVisual.
Context for Questions:
- According to the first reference document noted above, I must import a GSDML file into WorkVisual so that I can configure the device, in my case the device is the S7 1212FC. The procedure for "configuration with WorkVisual" says that the GSDML file must be obtained from the manufacturer of the device, in this case Siemens. I searched the Siemens online documentation to find GSDML files for the S7 1212FC and found an article instead of explicit GSDML files for downloading. Link to Siemens FAQ.
Question 1:
- Are the instructions listed in the Siemens FAQ the appropriate and /or correct method for configuring and generating a GSDML file for the S7 1212FC for use in WorkVisual?
Question 2:
- Will setting the S7 1212FC as an "IO device" in TIA Portal V17 cause it to be recognized as the "KRC4 Safety Interface via PROFIsafe" or just a "typical" PLC "IO device"?
Question 3:
- What differentiates the PROFIsafe PLC from the Profinet "non-safe" IO in WorkVisual?
Thank you in advance for any further clarification and/or insights.
Regards,
Benjamin Bigler
