Officelite: KSS 8.6.2
WorkVisual: 6.0.26
This one should be pretty quick, but I can't wrap my head around it.
This is the code:
GLOBAL STRUC T_CARR_POS_PAR E6POS APPR, READ, PREL, DEP, MOVE, E6AXIS XAPPR, XREAD, XPREL, XDEP, XMOVE, FRAME SCAN, OPEN, MIDDLE, CLOSE, PREL_OFFSET, DEP_OFFSET, CurrentPlane, InfPlane, SupPlane, BasePlane
It's a single structure composed by E6POS elements, the relative E6AXIS elements and finally some FRAME elements.
If I write this in a .dat file on WorkVisual no error is given. However, when the project is uploaded on Officelite, I receive this:
Error no. 2327 Type Expected.
I also defined a different structure with only E6POS variables and it works fine. The above-defined structure is, with many other, part of a bigger structure, but this is the only one which causes error.
Thanks for any help!
