LIN-REL Problem
  • I am new in kuka programming I have a problem in my program which is : path velocity not programmed.
    I defined A new tool which is FF2022.
    My program:
    PTP p1 VEL= 100 % PDAT1 Tool [1] : FF2022 Base [0]
    LIN-REl { y 50}
    The error here is path velocity not programmed.
  • Ahmed Ezzatt
    Changed the title of the thread from “LIN-REL Probelm” to “LIN-REL Problem”.
  • Lin-rel is not a valid krl command. Should be lin_rel.
    You must set the velocity, acceleration and so on before using movement commands.
    In standard robot programs this is done in the INI fold.
    You can call BAS(#init) at the very beginning of the program.
    Or you can call BAS(#vel_cp, 1.0) for setting the speed to 1m/s.
