Load data verification
  • EXOR
  • November 16, 2022 at 10:20 AM
  • EXOR
    19
    I'm currently trying to create a tool all numerically and have entered the mass etc.
    At the bottom I'm unable to enable the Overload/Underload because the "Load data verification has not been enabled."
    How do I enable this?
  • MOM
    175
    7
    1,419
    • November 16, 2022 at 10:47 AM
    User level?
  • EXOR
    19
    • November 16, 2022 at 10:56 AM
    Quote from MOM
    User level?
    Administrator, so it doesn't matter.
  • panic mode
    1,267
    13,037
    • November 16, 2022 at 2:47 PM
    what robot exactly?
    what KSS?
    is the tool already defined?
    what is value of $LDC_LOADED?
    yes Admin is above other accounts but... even Admin may not be allowed to do some settings. check Rights management, things could be set to "Deactivated"
  • freak
    17
    • December 19, 2022 at 10:03 AM
    Anyone has a solution to this problem? I have the same...
  • hermann
    405
    2,596
    • December 19, 2022 at 12:56 PM
    And panic_mode will have the same questions as before :winking_face:.
  • freak
    17
    • December 19, 2022 at 1:13 PM
    KR50R2100
    8.7.5
    Tool is defined.
    $LDC_LOADED = FALSE
  • panic mode
    1,267
    13,037
    • December 19, 2022 at 3:53 PM
    Quote from freak
    my oh my... life is so hard... apparently some find it difficult or too much effort to write a complete sentence. and someone is supposed to bend backwards to help them.
    you have the same... what? solution? robot brand?
    i don't even want to begin considering possible answer when people asking for something do not bother to describe the issue. a complete post would describe in shortest possible way all that is needed to replicate the problem. i see none of that.
    "i have the same..."
    well good for you, mister...
    as already suggested check user level and rights - things could be simply locked down.
    also is the robot even operational? maybe KSS does not want to see more things changed if ... i don't know... WoV project does not match the used system.. or current mode is AUT or EXT... or maybe the KSS is corrupt.... or maybe one of 10000000 other things...
    a well asked question should narrow possible answers to one or two cases.
    all too often people want help but don't even try so why should we? in general, i am not in the mood to start guessing and solving puzzles for those who do not want to make the effort themselves. sorry... the best tip i have is to read pinned topic READ FIRST. if that is too much, simply hire someone to take care of the problem. for $$$$$ everyone can get white glove service. no effort needed.
  • freak
    17
    • December 19, 2022 at 4:18 PM
    I have the same PROBLEM. Better?
    Well, you have typed 92 characters and it will never helps anyone.
    For all who wants to help:
    I've checked all the topics/tips above. I have the same Robot running on a KRC4 and there I can activate the load data verfication.
  • Fubini
    272
    1,872
    • December 19, 2022 at 4:41 PM
    Tried to set it directly on machine data?
    Post
    Re: Is it possible to disable tool overload messages and reaction?
    or maybe faster if you have many tools: edit $LDC_CONFIG[] array inside STEU/$custom.dat. The array index is the tool number.
    Fubini
    Fubini
    April 10, 2015 at 12:19 PM
    Fubini
  • freak
    17
    • December 19, 2022 at 5:56 PM
    • #11
    Thank you, I will try it tomorrow.
  • freak
    17
    • December 21, 2022 at 9:42 AM
    • #12
    It doesnt worked to set it directly in the machinedata.
    Kuka sent me a LDP.xml file, which I had to replace in
    C:\KRC\Roboter\Config\User\Common\Mada
    , now it works.
    Thank to all for helping.
Similar Threads
  • Load Data Tool problems.
    • foffulaRob
    • December 3, 2021 at 3:56 PM
    • KUKA Robot Forum
