KR C2 Stacker Offset
  • Kevin Wollmann
  • November 15, 2022 at 3:54 AM
  • Kevin Wollmann
    Hi All.
    I'm working on a Stacking robot that the customer wants to add a height offset of 10mm for everytime the robot drops a part. I haven't spent a lot of time with a kuka, but I hope i can get this to work. will the following work?
    (Pos1) top of the stack
    (Pos2) bottom of the stack
    (Pos3) offset temp
    (INT A) layers count
    (INT B) offset measurement.
    (INT C) temp
    PLC is doing the batch counting $IN(3308)
    robot acknowledge that the signal was received. $OUT(3342)
    if $IN(3308) == true then     //devicenet input
        PULSE($OUT[3342] , 1)    // pulseoutput signal to show plc robot reset the stacking
        POS3 = POS2                    // restore the temp position to the set point
        A = 0                                  // restore int to 0
    else
        A = A + 1                           // add layer
        C = A * B                           //multiply layer height
        LIN Pos3(a1 0, a2 0, a3 C, a4 0, a5 0, a6 0)   //new position
    endif
    PTP Pos1  //go back to top and cycle....
  • hermann
    412
    2,628
    • November 15, 2022 at 6:49 AM
    Can't follow your logic, but at least
    Won't work.
    Wrong Syntax. Think you forgot a ':', but that's not enough.
    You want to give offsets in cartesian coordinates (not axis values) so you have to use x, y, Z, a, b, c instead of a1, a2...
    You can't use variable like C in the offset frame direct, you need to declare a frame and then set the components separate like:
    Decl frame offset
    Offset=$nullframe
    Offset.z = C
    Lin offset:offset
    Changed the order around ':', as in palletizing programs normally offsets are relative to base.
  • panic mode
    1,297
    13,141
    • November 15, 2022 at 3:46 PM
    that is correct except for typo in line 4,
    to offset base should be
    LIN offset:Pos3
    to offset tool should be
    LIN Pos3:offset
  • Kevin Wollmann
    • November 18, 2022 at 1:30 AM
    Hi, what is wrong with the following code.
    This is in my DAT file
    DECL FRAME Ofset
    DECL INT A
    DECL INT A1
    DECL INT B
    DECL INT C
    This is in my SRC File. I get the error on the Ofset line.
    PTP P8 Vel=30 % PDAT4 Tool[1] Base[0]
    LIN P9 Vel=0.2 m/s CPDAT5 Tool[1] Base [0]
    A = A + 1
    A1 = 120 - A
    B = 10
    C = A1 * B
    Ofset = $nullframe
    Ofset.z = -C
    LIN P9:Ofset
    PTP P10 Vel=30 % PDAT6 Tool[1] Base[0]
    PTP P11 Vel=0.2 m/s CPDAT7 Tool[1] Base [0]
  • panic mode
    1,297
    13,141
    • November 18, 2022 at 4:36 AM
    You may want to be more specific...
    Which line of code exactly and what kind of message?
  • Fubini
    283
    1,905
    • November 18, 2022 at 8:18 AM
    Could be it needs to be XP9 in line 11 since its defined inside an Inline form.
    Fubini
  • hermann
    412
    2,628
    • November 18, 2022 at 8:31 AM
    -C
    should be
    -1.0*C
  • DannyDJ
    67
    506
    • November 18, 2022 at 9:01 AM
    Usually value of inline points in .dat is stored with X prefix. So if you want to use values from inline form point P9, one should write XP9 in program.
    LIN XP9:ofset
  • variable
  • global
  • positions
  • dat
