Equipment for KUKA oil change
  • ophakala
  • November 14, 2022 at 11:21 AM
  • ophakala
    40
    Hi, just curious about what kind of equipment do you usually use to change the oil for KUKA robots?
    For axis 3-6 it`s easy to fill the right amount effectively but for axis 1 and 2 it can be little tricky sometimes if you don`t want to spend whole day applying the oil. In the previous company I worked we used one kind of vacuum pump to apply the oil for those bigger ones. Now in the current company we don`t have similar device so I´m thinking what would be the best solution to purchase. I know that you can`t push the oil inside with pump because there`s risk that the seals don`t last.
    My colleagues had KUKA training about maintenance before but they were using like medical injection equipment to change the oil. For axis 1 and 2 it will take forever using that method. So yeah, would be nice if someone has a good idea how to perform that oil change.
  • the leg
    643
    • November 25, 2022 at 11:14 AM
    Kuka use a pump system to fill axis 1 - 3
  • ophakala
    40
    • November 25, 2022 at 12:49 PM
    Yes, I found similar thread about oil change and there was a link to that kind of oil dispenser. Maybe it`s safe to use pump carefully then.
