Hi guys!
Your advices and recommendations will be highly appreciated. The post become quite long so please bear with me.
On my robot, I have gripper as the one attached. Here are my issues/doubts.
The gripper is attached on fastchanger. How to put this? I see that when I place the gripper in home position, the current position value for R (rotation over Z axis) is 105 degrees, which means that there is some turn around J6 at the beginning (not realize this at the beginning). Please see attached Roboguide picture.
I did some programming and experiments, also teach some points into position registers. Now I realize that my tool frame:
- Z axis points down
- X axis points right (when you are at the robot’s back) – also as you can expects it is not parallel to UF X axis, but rotate some degree clockwise
- Y axis points away, when you are at the robot’s back) – also as you can expects it is not parallel to UF Y axis, but rotate some degree clockwise
Here are my questions:
- How to make tool frame first setting (Three point method), when having a gripper as mine? I am afraid about pneumatic pipes and cables, when I need to turn the gripper!
- What are you recommendation regarding the position of Tool Frame axis? In YouTube as see example, where Tool Frame orientation is the same as User Frame and also examples where Z axis is pointing down. The reason for the lather is when you approaching to the point, your Z coordinates to be positive. I bother a lot, because I use Tool_Offset a lot in my programs and find it very useful.
- It is important, when I turn the gripper around Z axis at some angle (90 or 180 degrees) to return it back, but in opposite direction, because of the cables and pipes attached to the gripper. It turns out that depending of the motion type (J or L) of motion instruction, the rotation in one direction is fine, but when I try to return gripper in start position, it continue to rotate clockwise but not counterclockwise as I needed. What are the rules, which control the direction of rotation of the J6 axis?
- Regarding the previous question, the rotation is according the Z axis of tool frame selected, when I use Tool_Offset for rotation – right?
Best reagrds,
Yolov
