LIN-Motion slow?
  • Hi,
    I’m currently working on a project containing one KR16 - KRC5.
    I’ve written in a previous thread that I’m a previous ABB-programmer.
    I’m having issues with the speed of some ”short” LIN-motions. (It’s a movement of 500mm or so)
    I’m using full acceleration and 2m/s but the movement still seems pretty slow compared to the PTP ones.
    Is it something obvious when working with LIN-motions that I’m maybe missing out?
    (I’ll paste the code later, just putting this here if anyone knows something of this little information above)
  • When exactly does this happen?
    - In which operation mode?
    - How short are the moves?
    - Is it better when using SLIN instead of LIN?
    - Is it better if you use spline blocks instead of single motion command with blending?
    - Do you use blending? Which type with what blending configuration?
    Just to many possibilities with that minimum amount of information you are giving. Please show at least your program.
    Fubini
  • Ptp will always beat Lin or atleast be equally fast in my experience. 2m/s is no where near max. Whereas 100% on ptp is max.
    I usually put the speed by setting the speed from what is defined in $VEL_MA. As those are the maximum values. If you absolutely need the last squeeze of speed your robot can muster.
    To set max linear speed (.CP) and orientation (.ORI1 and .ORI2)
