Configure input e output
- robiguglielmi88
- Thread is Unresolved
Make a cross connection from both inputs to the three outputs.
You do it in the IO configuration of RS just like you defined the signals. Just look for cross connection.
You do it in the IO configuration of RS just like you defined the signals. Just look for cross connections
The "actor" is the signal that acts on the resultant. You will need to use AND also. The manual for using robotstudio is available in the help tab.
Maybe offtopic, but it has to be said: Why are you writing in code brackets all the time?
