as i recall there is an option to increase speed progressively (1,3,5,10,30,50,75,100) or in 1% increments. and all this should be in HMI config files so if needed one should be able to adapt it.
even if that is not the case (values hardcoded in some DLL for example), nothing stops user from monitoring override value change and when detected apply desired increment/decrement using own step value.
