Register math
  • Hey all, I’m taking a beginners Fanuc programming class, am trying to make a shape with using only one PR, and the rest will be with register math , I can’t use the PR offset is this possible? If so any info would be greatly appreciated.Thanks
  • it will be something like
    L PR1 Move to the point
    PR1,1 = PR 1,1 + 5 Add 5 mm on the x
    L PR1 Move 5 mm on the x from the point
    PR1,3 = PR 1,1 + 7 Add 7 mm on the z
    L PR1 Move 7 mm on the z from the point
    If you want to , you can put the 5 and 7 on R and do the math with the Rs
    Retired but still helping
  • Ok so the only thing is I’m not suppose to use the PR(I,j) only data registers and one motion point like a L PR1 then data registers to finish the shape
  • Says,
    Create a new program that will draw a square using the following requirements.
    Only allowed to use 1 move instruction like
    J PR
    Using register math along with conditional branching to make robot draw a square.
    Our previous assignment was the same except using one PR with offsets so I took this to mean only data registers in this one.
  • Ok that’s what where I was at as well, I’m gonna have to get some clarification from the instructor next week , was wanting to make sure that I wasn’t just missing the whole thing , will let you know when I get more info Thanks for the help
