Melfa Basic VI - If...Then...Elseif...Endif Syntax Help / Examples
  • I have a simple syntax question concerning Melfa Basic VI If...Then...Elsif...Endif statements.
    What I want this routine to do is this - Based on the exteranl inputs run specific subroutine and if none are true goto a holding Position (posXXX).
    The way I currently have it programmed is working except for when none of the Inputs are true, The program goes to the next subroutine.
    *Box1, *Box2, *Box3 are subroutines. posXXX is the default/ holding position.
    If M_In(11) = 1 Then *Box1
    If M_In(12) = 1 Then *Box2
    If M_In(13) = 1 Then *Box3
    I have read all the Mitsubishi documentation on thes If/Then/Elseif statements and every time I try to include the last "Else" condition I get syntax errors.
    Any help is appreciated, program examples welcome.
    Thanks in advance.
  • Place your Ad here!
  • Without knowing Melfa Basic, somethink like this should work:
    it would be better:
    1. posting one of your faulty trials
    2. posting a bit more of your code, at least some lines following the If/Then/Else . :winking_face:
    • Helpful
    Goto is suboptimal. Make a local subroutine and use GoSub.
    When the subroutine is finished, the program pointer jumps back to the place where it was called.
  • Thank you all for your responses.
    BO,
    The script you have is exactly how I have been keeping this process moving fwd.
    But I know there is a more standard way to write this routine. I just kept hitting syntax errors.
    HE,
    I had tried your idea and still received syntax errors.
    Roland,
    Your idea worked great! Below is the working program.
    *BoxEval
    Mvs posPostScan
    If M_In(10) = 1 Then
    GoSub *Box6
    Break
    ElseIf M_In(11) = 1 Then
    GoSub *Box1
    Break
    ElseIf M_In(12) = 1 Then
    GoSub *Box2
    Break
    ElseIf M_In(13) = 1 Then
    GoSub *Box3
    Break
    ElseIf M_In(14) = 1 Then
    GoSub *Box4
    Break
    ElseIf M_In(15) = 1 Then
    GoSub *Box5
    Break
    Else
    GoSub *BoxEval
    EndIf
    Roland - "Goto is suboptimal. Make a local subroutine and use GoSub.
    When the subroutine is finished, the program pointer jumps back to the place where it was called."
    I'm a rookie with Melfa Basic and have always used "Go To" instead of "GoSub".
    What are the practical differences between GoTo and GoSub?
