  4. ABB Robot Forum
ABB S4C+ Load system module
  • EladYahni
  • October 21, 2022 at 3:48 PM
  • EladYahni
    39
    Hello everyone
    I have abb robot with controler s4c+
    and I want to delete the user or base program from the robot memory and load it back into the robot
    can someone tell me how to do it?
    Many thanks
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • October 21, 2022 at 4:27 PM
    To delete first is an unnecessary step. View modules, load module, navigate to the directory where the module is stored. Select USER or BASE, whichever is desired. Load it, you should be prompted that there there is already a module with that name, confirm to overwrite it. Done.
  • EladYahni
    39
    • October 22, 2022 at 12:31 PM
    Hello Lemster68
    Thanks for your answer
    I did it according to your way but when I run the main module and once I want to use the variables that are in the base module or in the user module i get an error
    the variables I defined in the basic model were not found
  • SomeTekk
    16
    201
    • October 24, 2022 at 1:27 PM
    It would make it easier to provide suggestions if the error codes and RAPID programming were able to be shared.
    Edited once, last by SomeTekk (October 25, 2022 at 1:53 PM).
  • EladYahni
    39
    • October 26, 2022 at 7:33 PM
    Hello Some Tekk
    Thanks for your response
    The problem is that the program stops and I get a variable not existing error
    for example
    If I define a speeddata variable inside the base.sys file and I'm trying to use it inside the main program I get an error that it doesn't know this variable
    But if I go into the base file in the rapid folder via ftp I see all the variables exist
    my question is how can I reload the file into the robot memory
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • October 26, 2022 at 7:39 PM
    Look at the data from the VIEW function key. Find the one that you have created, if it is there. If you had a syntax error, it will not have loaded your module that you think is loaded. Also, you could view the module in the editor of the pendant. Make sure that it is type PERS or CONST.
  • EladYahni
    39
    • October 26, 2022 at 7:44 PM
    I will check it tomorrow morning
    thank you very much
  • EladYahni
    39
    • November 4, 2022 at 10:17 AM
    Hi Lemster68
    I did it according to what you said, it worked.
    Thank you very much for your help
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • November 4, 2022 at 12:56 PM
    Good. You are welcome. :thumbs_up:
Similar Threads
  • ABB S4c+ M2000 FLASH DISK 64MB don't work after clone ( the original and the clone)
    • paulofutre10
    • April 15, 2021 at 6:12 PM
    • ABB Robot Forum
  • ABB S4C+ Won't Boot: Infinite Count-Up on Teach Pendant
    • Gangacian_111
    • February 28, 2022 at 4:22 PM
    • ABB Robot Forum
  • s4c+
  • abb s4c+
