  4. other Robots
Epson task running problem
  • Nelson Salgueiro
  • October 15, 2022 at 9:07 PM
  • Nelson Salgueiro
    Hello everybody,
    I'm having an issue regarding an EPSON T3 (and also T6) that i would like some help:
    I'm trying to edit a program in a running robot, and when i connect to it, i got a pop-up with the following message:
    "The controller is running tasks for the current PC project.
    Would you like to monitor operation? YES / NO"
    i thing i know what it means, since i can open the program from the controller:
    I thing that the task 65 is running (bgmain), and i can not get access because of that.
    But i can´t find a way to stop it, to edit the program.
    This machine also has a T6 running in it, and i got the same problem.
    I really need to edit the program, because of an hardware change, (gripper) the robot is colliding with the parts to pick/place.
    This may be a newbie question, but i appreciate all the help, please.
    Thanks in advance
  • nmcquiston_kb3yzk
    • December 31, 2022 at 3:43 AM
    An estop will stop the task.
  • Nelson Salgueiro
    • January 3, 2023 at 9:52 AM
    Hi and thank you for your answer,
    Quote from nmcquiston_kb3yzk
    in this case, the estop didn't stop the task.
    The only way it stopped that task was using the TP3, and put it in T1 and then in test mode. (i found that information in the Epson manual)
    To prevent this in the future, instead of running that task as a background task, i changed it to a normal task.
    Now it can connect with no problems of tasks running.
    Hope this helps anyone with the same problem
  • epson
  • Task
  • T3
  • T6
  • bgmain
Users Viewing This Thread
  • 1 Guest
