By chance someone has the files of the recovery folder of the usb memory of the iiwa 7 r800 model samvaria la vida
iiwa 7 r800 USB recovery
- Samuel Garcia
- Thread is Unresolved
Muy Gmail is samuelgarciacerda98@gmail.com
Could someone help me? I have this situation. I clicked on the firewall option and it went into old mode and now I get this as if it were factory mode, but I don't have the kuka iiwa usb memory. Any solution?
panic mode
Moved the thread from forum KUKA Robot Forum to forum KUKA LBR IIWA. -
welcome to robot forum. please make sure to post in correct subforum and keep one topic in one thread.
iiwa 7 r800 is a robot arm. that is not relevant here since SunriseOS and firewall do not run on it, both are running on the robot controller.
the image contains bunch of licensed software and sharing that here is software piracy. do not ask for things that are illegal or that will get you banned. If you need image, you need to contact KUKA.
If you need help recovering or reverting some setting, you should state exact version of the SunriseOS that your system uses and steps you used to make the change.
As panic mode says, you should contact KUKA customer service.
