Inverted IRB 1400
  • I know the irb 1400 H is the designed robot to be hung upside down.
    Can you though invert a standard irb 1400?
    I see axis 1 gearbox oil will need filling up.
    Or maybe the question is why can't you invert a standard irb 1400?
    Mig welding application and Irc5
  • Not a lot of options with IRB1400. The 1400 spring balancers are designed for floor mounting. Deviating away from that will affect load characteristics. The 1400H has a short lower arm giving less reach to compensate for the lack of balancing springs.
    The 1400 design came out with the M94 model so it had a good run.
