ABB Bullseye - tool
  • Hi.
    I have a welding cell with one welding robot and I am using the 22° weld gun. For the new project i will have to use 45° weld gun. The gun will be changed manualy.
    Is it possible to use bullseye in automatic mode for 2 different tools in my case weld guns? So when I change the gun can I check the bullseye in production manger?
    Best regards
    Luka
  • Yes, you can run multiple tools in the bullseye. Each will be required to be set up at start. When running, you will have to manually change the tool in the quickset menu. After selection you can create a procedure that will check the current data of the current tool, evaluate then run the correct bullseye routine.
    Something like this sample.
