Modify Position Variable
  • Noob1982
  • September 21, 2022 at 6:30 PM
  • Noob1982
    111
    Is there a parameter that allows you to modify Position Variables from the job screen using modify enter?
  • Robodoc
    56
    7
    1,061
    • September 24, 2022 at 2:10 PM
    No. Position variables are a separate file from a job. You must be in the position variable to modify it.
    Robodoc
  • WattUp
    7
    96
    • September 26, 2022 at 3:05 PM
    You can quickly edit a PVAR by highlighting the line, then hit OPEN DIRECT.
    It will bring up the PVAR setting directly.
    Hitting again will bring you back to the job.
  • Woebot
    5
    24
    • September 29, 2022 at 8:13 AM
    Quote from WattUp
    Thank you I didn't know this and just tried it. super helpful! Also worked for extended language PVars in my program (ie. P[I000]
  • WattUp
    7
    96
    • October 3, 2022 at 3:43 PM
    Quote from Woebot
    It's a super handy trick that a lot of programmers I've worked with didn't know.
    Also works for opening Call : Job statements
Similar Threads
  • Fanuc Skip Touch
    • casper
    • November 13, 2019 at 8:19 AM
    • Fanuc Robot Forum
  • Destination Pulse Limit in DX200
    • Gurtej Singh
    • September 10, 2021 at 5:18 PM
    • Yaskawa Motoman Robot Forum
  • XRC - Tool Data modification
    • lostcontrol
    • October 8, 2020 at 11:24 AM
  • Comment utiliser les repères utilisateur sur Motosim
    • Basteak
    • August 6, 2020 at 12:13 PM
  • Using interrupt to store values
    • chis
    • February 25, 2020 at 11:10 PM
    • KUKA Robot Forum
  • Get Current Active Tool
    • RockyLeafs
    • July 25, 2019 at 9:51 PM
  • Dx200 Macro Argument Definitions - R POS
    • BGFanatic
    • January 3, 2019 at 10:58 PM
  • Unlucky line 52 - Changing the position of the robot
    • Dawid Firlej
    • November 19, 2018 at 1:32 PM
    • Kawasaki Robot Forum
  • KUKA Cartesian Position Direct Entry
    • Kosy
    • August 22, 2018 at 5:59 PM
    • KUKA Robot Forum
