New robot, unwanted programs
  • Duranthas
  • September 13, 2022 at 1:57 PM
  • Duranthas
    39
    On a brand new robot, it came with quite a few programs that I would like to either delete or hide somehow. There are TP programs such as CLSKP, CLSKP_EX, CLSKP_G2 (and it goes G2-G8), and SETSKCOL, There are tons of VR & PC, and a handful of macro (MR) programs such as AAVMFREEPOS (VR), AAVMMAIN (PC), CBPARAM (VR), COMSET (PC), GEMDATA (PC), GETDATA (MR), GET_HOME (PC), HTCOLREC (VR), HTTPKCL (VR), IPRNGSET (PC), IPRNGSHO (PC), IRC_COUNTER (PC), IRC_MSG (PC), IRC_STATUS (PC) IRC_STLABEL (PC), IRVTYPE (VR), REQMENU (MR), SENDDATA (MR), SENDEVNT (MR), SENDSYSV (MR), SETSKCKL (PC), SFIGET (PC), SV_ADJUST (MR), SWIUPDT (VR), TBSWMD45 (PC), TPSNAP (PC), VCMRINIT (PC), VC_MOVE (PC).
    Obviously some of that is for collision skip stuff, but we don't even use that feature. I have backups of everything, so is it safe for me to delete these or is there something here I'll be unknowingly be using? Or is there a way to permanently hide them? And I am aware that from the select screen I can hit F1 for TYPE, and select only TP programs, but I'm 100% confident that someone on the floor will muck about and change that, freak out, and then I get a call because it looks different.
  • Janusz robotyk
    5
    13
    • September 13, 2022 at 2:54 PM
    You can execute Controlled Start and set "NO" in 2. Karel Prog in select menu.
    You can still call those programs within your programs, but they will not show in select menu.
    In newer versions on controller's software, you cannot delete system macros (GETDATA.MR, SENDDATA.MR etc) for some reason.
  • Duranthas
    39
    • September 13, 2022 at 3:21 PM
    Thanks! I appreciate this info.
  • Fabian Munoz
    134
    Articles
    1,517
    • September 13, 2022 at 3:30 PM
    May I ask, what is the problem for having all those programs in memory.
    I have them but when I'm working I only see the TP programs (because I selected that)
    In the case of CLSKP, CLSKP_EX, CLSKP_G2, make them macros and therefore you will not see them in your TP list
    Retired but still helping
  • Duranthas
    39
    • September 13, 2022 at 3:50 PM
    We only use a handful of TP programs. Basically MAIN, which calls RECOVERY, and from there, MOV_HOME, MOVE_MTC, GET_PART, and PUT_PART. That's about it. I'd like it is the screen only showed those programs, and no others. As for changing the type to only show TP programs, that will work, except I'm positive that someone will be kind enough to fat finger or muck around and change it to something else which results in me getting a call. Once they changed it to MACRO and of course freaked out because it didn't list the needed programs. If there was a way I could make it only show TP programs, and not allow that to be changed, it would also work well.
