how make it so i can enable teach pendent during production?
  • cat91345
  • September 12, 2022 at 4:12 PM
  • cat91345
    175
    I have disabled all of the bits in the PLC that prevent program from running while in production. I am assuming all that is left is something internal within the robot. How can I fix this so I can make simple corrections while in production. As of now, if I want to do something as simple as change the speed, I have to take robot out of production. Thank you
  • HawkME
    570
    3,269
    • September 12, 2022 at 4:23 PM
    Use Background edit. At the top of the select screen is a file called bckedt. You select that first, then select the program you want to modify, then make and apply the changes.
    However you cannot apply the changes if that program is currently running. It's works best if you have a main program that calls sub programs and you don't need to edit the main. Then it is pretty easy to apply changes to any sub programs. You just have to hit the apply button while that sub isn't currently being called.
  • JeffBO
    13
    • September 13, 2022 at 10:39 AM
    Quote from cat91345
    You can also use indirect values for motion speed, thus use registers to change the speed without stopping your production.
