Arduino servo and ultrasonic sensor coding trouble
  • Hello, I'm trying to make an obstacle-avoiding robot using an ultrasonic sensor and 2 servos. and when my sensor kicks in I just want one leg to move but the right still moves but in a delay. What can I do to fix this?
  • Place your Ad here!
  • Create a separate function that controls your servo first. No reason to dublicate your code multiple times.
    void moveServos(int servo1Position, int servo2Position)
        // from your global variable use your servo objects
        myservo1.write(servo1Position);
        myservo2.write(servo2Position);
    As I understood you have a small cart or else. Each servo controls it's own side - left/right. In this case you always control both sides. Then modify your logic upfront to do calculation for 2 servos always and you wont have any issues. If you want to delay for one of the servos, then send same position and you wont have issues. You need to reorganize part of your code(below) to make calculation always for both legs to make sure that you wont have any issues whatever leg you are using at the moment.
    if(distance_cm < DISTANCE_THRESHOLD) {
    for (pos = 0; pos <= pos3; pos += 1) {
      myservo1.write(pos);
      delay(15);
      for (pos = pos3; pos >= 0; pos -= 1) {
      delay(15);
