Home Position (mastering)
  • Vlad222
  • September 1, 2022 at 12:01 PM
  • Vlad222
    161
    Hi all,
    I have retrofit cell with old YASKAWA 3100, DX100. There was different HOME POSITIONS at teach pendant and in controller. Robot owner doesn't know about this difference. They didn't have replaced motors, memory, etc. I think that it's operator's mistake and I want to return pulses from paper in controller.
    May be they had dead battery? Is need to change HOME POSITION in the case of replacing battery in robot random position? Or HOME POSITION will be constant in cases with battery problems?
  • Go to Best Answer
  • TSGIR
    81
    715
    • September 1, 2022 at 1:25 PM
    If the problem is from battery you will give battery error on pendant and also after turn OFF and ON the data in HOME POSITION page will be lose and you see * in front of axis that have battery problem.
    The difference between HOME POSITION data and label data in controller isn't because of battery, maybe when you buy the controller the data in HOME POSITION changed but they didn't update data on the label.
    For check that the value in HOME POSITION is correct or not, go to SECOND HOME POSITION and turn servo ON and hold FWD key, robot will go to home. After that check the marker on each axis, if all marker are in front of markers on axis your home is correct and the data on the controller isn't important but if your home was incorrect check with value in the label.
  • Vlad222
    161
    • September 1, 2022 at 6:19 PM
    Am I right that pulses in the controller door junk after battery lost power? Robot was in random position
  • TSGIR
    81
    715
    • September 1, 2022 at 8:07 PM
    • Best Answer
    The pulses in label door is default pulses and original home pulses but if you lose battery these data couldn't use in your robot and need new data.
Similar Threads
  • Homing a KRC2 query
    • marbles
    • March 8, 2022 at 7:56 PM
    • KUKA Robot Forum
  • array/grid-wise measurement with kuka robot
    • El_Mo
    • June 25, 2022 at 3:43 PM
    • KUKA Robot Forum
  • Activate same DO to several home positions
    • BrainKaput
    • April 29, 2022 at 8:41 AM
    • Fanuc Robot Forum
  • Mastering Data
    • Stefan28
    • October 27, 2021 at 1:35 PM
    • KUKA Robot Forum
  • SRVO-062 BZAL Alarm
    • byrol
    • June 21, 2019 at 9:46 PM
    • Fanuc Robot Forum
  • Mastering after BZAL, cannot achieve zero
    • bebeeni1
    • November 25, 2019 at 2:37 AM
    • Fanuc Robot Forum
  • Kuka KMP 200 omniMove not moving
    • BCrinion
    • April 23, 2019 at 10:05 AM
    • KUKA LBR IIWA
  • S-10 Motor Overheat
    • droth
    • March 29, 2019 at 12:46 PM
    • Fanuc Robot Forum
  • Robot not moving correctly (Cartesian koo. system)
    • leeroi
    • November 7, 2018 at 11:22 AM
    • Yaskawa Motoman Robot Forum
