User key
  • Hello all.
    I am using KR300R2700 - 2F / FLR
    With KRC 4 Controller
    Application - Pick & Place. (Material Handling)
    First i am using separate user keys for gripper open & gripper close. I am using this keys as
    In SPS.
    IF Is_Key_Pressed(14) THEN
    Gripper Open pulse.
    ENDIF
    IF Is_Key_Pressed(15) THEN
    Gripper Close pulse.
    ENDIF
    I want to open & close gripper on same (single) button.
    As like, if gripper is open then it will be close & if gripper is close then it will be open.
    I think, setting a flag is better option, but please suggest best way to use a single button.
  • Hello;
    First of all, you should have sensors that see the open and closed position of the gripper. your sample program should be like this;
    $IN[1] : Your Gripper Open/Close Button/Command
    $IN[2] : Gripper Opened
    $IN[3] : Gripper Closed
    $OUT[1] : Gripper Open, Output *
    $OUT[2] : Gripper Close, Output *
    IF ($IN[1]==TRUE) THEN
    IF ($IN[2]==TRUE) THEN
    $OUT[2]=FALSE; *
    WAIT 0.1;
    $OUT[1]=TRUE; *
    ELSEIF ($IN[3]==TRUE) THEN
    $OUT[1]=FALSE; *
    WAIT 0.1;
    $OUT[2]=TRUE; *
    ENDIF
    ENDIF
    * if your valve is permanent type, not spring return PULSE can be used. Etc;
    PULSE($OUT[1],TRUE,0.5)
    PULSE($OUT[2],TRUE,0.5)
    ENDIF
    ENDIF
    Think before you talk, Read it before you think about it.
    Fran Lebowitz.
  • I want to open & close gripper on same (single) button.
    You'll need some sort of memory latch to create an edge-trigger on the button.
    This should flip the True/False states of both outputs when the button is pressed, but not keep flipping them every SPS loop if someone hold the button down. The idea of the memory BOOL is to make the IF statement only trigger once, when someone presses the button. Then it cannot trigger again until the button is released, then pressed again.
  • I Already have sensors,
    But i does not understand that , how can i get $IN[1] ??
    How to get input after preessing certain status key ??
  • You'll need some sort of memory latch to create an edge-trigger on the button.
    You mean, first of all, i have to declare an BOOL i.e. bButtonMemory. Inside confg.
    & then i will write all your logic in SPS.
    Am I right ?? ?(
  • you cannot get input activated by pressing status key. at least not directly because inputs are read-only.
    you could write code that activates output... the output could be wired to input (or echoed back in a PLC for example...)... then you have input that corresponds to status key state
    yes all variables need to be declared before use. where and how you declare and initialize them will have impact on life and scope of the given variable.
