How to run LS file through the USB
  • shpersia
  • August 29, 2022 at 2:05 PM
  • shpersia
    8
    Hi
    I am working with R30ib Plus Fanuc Controller. I have generated the G-codes from RoboDk in LS file, but when I want to load it through the controller via USB, I have faced to this message" the file is not loadable".
    So could you please let me know what should I do at this step?
    :smiling_face:
    Edited once, last by shpersia (August 29, 2022 at 7:08 PM).
  • massula
    204
    8
    1,427
    • August 29, 2022 at 3:40 PM
    Does Your robot have the ASCII upload option installed? If not, You can't load a program in .ls format. You need co convert it to .tp format before.
  • massula August 29, 2022 at 3:41 PM
    Moved the thread from forum General Robotics Discussions - everything but NO Industrial Robots to forum Fanuc Robot Forum.
  • shpersia
    8
    • August 29, 2022 at 5:54 PM
    Thanks Massula, how can I find my controller has ASCII upload option installed? and if it does not have this option, how can I install it?
  • Fabian Munoz
    133
    Articles
    1,517
    • August 29, 2022 at 5:57 PM
    You have to call Fanuc, they will activated using a PAC code number
    Retired but still helping
  • shpersia
    8
    • August 29, 2022 at 6:39 PM
    Thanks Fabian!
  • massula
    204
    8
    1,427
    • August 29, 2022 at 7:22 PM
    To know if your robot has ASCII upload option installed:
    If You have an All Of Above backup, You can pick the SUMMARY.DG file, open it with any text editor, an search for ASCII Upload and/or ASCII Program Loader Options in the CONFIG:: section.
    Something like
    Ascii Program Loader  R796
    Ascii Upload          R507
    If You have access to the real robot, You can also check this information at MENU > 0 Next > 4 STATUS > 4 Version ID (numbers can vary).
    Inside Version ID screen, You press F3 [CONFIG] and scroll the list. Is the same list contained on the CONFIG:: section of SUMMARY.DG.
    To obtain this option, in case You robot doesn't have it, as Fabian mentioned, You need to call FANUC. This is a paid option.
  • shpersia
    8
    • August 29, 2022 at 10:20 PM
    Hi Massula
    Thank you!
  • shpersia
    8
    • August 31, 2022 at 2:49 PM
    Hi
    I have converted the file from the LS to TP and put the program into USB. I have followed these following steps, but I could not run the program:
    1-Insert USB to teach pendant
    2-menu>file>utility>set device>select program>load>run>overwrite
    3-turn teach pendant off and put controller in Auto position
    4- When I press the Cycle start, my program is not able to run
    so could you please let me know what can I do to run my program?
    SkyeFire
    1,052
    9,429
    • August 31, 2022 at 2:58 PM
    Quote
    How, exactly? Were there any error messages?
    Quote from shpersia
    Do any messages occur when you do this?
    Quote from shpersia
    Did you select the program first? Are your SIO and UIO set up correctly?
    Quote from shpersia
    Again, what messages occur when you do this?
  • shpersia
    8
    • August 31, 2022 at 3:11 PM
    Thanks SkyFire
    I have these errors including sys-011 and sys-047 to run the program, so may I know how to solve them?
    Edited once, last by shpersia (August 31, 2022 at 5:53 PM).
  • massula
    204
    8
    1,427
    • August 31, 2022 at 6:06 PM
    • #11
    On Menu > Next > System > Config, how is the option Remote/Local setup is configured?
  • shpersia
    8
    • August 31, 2022 at 6:37 PM
    • #12
    Thanks Massula, I have checked it and I do not think it was configured?
    I have seen these following information:
    Remote/ Local setup: Local
    External I/O (ON: Remote): DI [ 0]
    Edited once, last by shpersia (August 31, 2022 at 6:42 PM).
    SkyeFire
    1,052
    9,429
    • August 31, 2022 at 7:46 PM
    • #13
    Quote from shpersia
    Thanks SkyFire
    I asked 4 questions, you answered 1. I'm finished here.
  • shpersia
    8
    • August 31, 2022 at 7:59 PM
    • #14
    I have received the LS program and changed it to TP program through the Roboguide.
    after loading program, I have received this
    TP already exist and syst-179
    I did select program and did not do SIO and UIO (could you please let me know how should I do it?
    After loading program to do cycle start, I have faced to these errors including sys-011 and sys-047 to run the program, so may I know how to solve them?
  • bodimat1707
    • September 14, 2022 at 3:30 PM
    • #15
    You need ASCII upload option.
    BR,
    Bodo
  • Jeremy RoboDK
    17
    75
    • September 29, 2022 at 7:30 PM
    • #16
    If you don't have ASCII Upload, your can take a look at this other option to convert LS to TP.
    Jeremy
    RoboDK - Simulation and Offline programming software for industrial and collaborative robots.
    Visit us at RoboDK.com
    Take a look at our tutorial videos on our YouTube channel.
  • SpraggSwagg
    5
    • March 11, 2024 at 3:01 PM
    • #17
    Do you know what version of robot you have? Anything v9.4 or higher exports .ls files with a "LOCAL_REGISTERS" line in the program settings at the top. Unless someone else has a solution, I have not been able to download these .ls files to the robot via USB until I delete this line. Maybe this would be something you can check?
Similar Threads
  • File-064 Unspecified DOS System error:60
    • Darkbound
    • October 3, 2019 at 8:03 AM
    • Fanuc Robot Forum
  • Booting KRC4 recovery system from any USB Flash Drive
    • VDm
    • February 21, 2020 at 6:26 PM
    • KUKA Robot Forum
  • K-Roset: A beginner’s journey
    • Dave Hudnutt
    • January 23, 2019 at 5:31 PM
    • Kawasaki Robot Forum
  • Vision Programming NiryoOne
    • astabc34
    • June 6, 2022 at 9:39 AM
    • other Cobots
  • Fusion 360 -> Fanuc System R-J3iB
    • fungus
    • January 18, 2021 at 3:52 PM
    • Fanuc Robot Forum
  • Extended TP memory
    • mosbe
    • June 19, 2021 at 7:28 PM
    • Fanuc Robot Forum
  • Karel server for constant input data updating
    • dcrb
    • March 8, 2021 at 4:16 PM
    • Fanuc Robot Forum
  • Fanuc Security Access with an ID badge
    • Leonidas
    • May 17, 2019 at 4:27 PM
    • Fanuc Robot Forum
  • EPSON GUI (Error 7713)
    • mmarty4
    • January 13, 2021 at 11:35 PM
    • other Robots
  • Unable to boot usb drive
    • andoors2011
    • May 22, 2019 at 3:36 AM
    • Universal Robots
  • usb
  • LS File
  • Running G-codes
  • file is not loadable
