Kuka robot KUKA.Ethernet - KRLGetFrameArray
  • Hi everyone, I would like to send about 250 points from the PC to the robot via KUKA.Ethernet KRL.
    I found that there is: RET = EKI_GetFrameArray(CHAR[], CHAR[], FRAME[])
    in the pdf manual they gave an example: RET = EKI_GetFrameArray("Channel_1", "Root/TCP", MyFrame[])
    TpQG2Prz
    I'm not sure how to write the xml file for the array (they did not write that example):
    Can anyone help me with this, thanks in advance.
  • massula
    Approved the thread.
  • yup, the EKI could use more examples and details.
    i have not tried array but according to good folks at German robot forum it works.
    so you would need only one tag element
    <ELEMENT Tag="Root/TCP/POS" Type="FRAME" />
    and then read entire array using
    RET=EKI_GetFrameArray(xmlCfgFile,"Root/TCP/POS",FRAMEARRAY[])
    and make sure your XmlCfgFile has buffer sufficiently large
