  4. Mitsubishi Robot Forum
Change robot speed from PLC
  • beneadaniel
  • August 25, 2022 at 2:47 PM
  • beneadaniel
    I have one robot Mitsubishi FR-D series CR800 -- RV2FRB-D how communicate with one PLC via Profinet.
    I want to change the robot speed from PLC but I don't know how.
    Let me know if you have any suggestions!
    Thanks!
  • Gambit
    • September 5, 2022 at 3:44 PM
    I don't think you can create an OVRD with a value from profinet, But you could make a Case statement with for a selection with some hard OVRD values,
    Select MCNT
    M1=10 ' This line is not executed
    Case 1
    OVRD 100
    Break
    Case 2
    OVRD 50
    Break
    End Select
  • Jakub Belniak
    • September 21, 2022 at 9:08 AM
    Hello
    You need to to configure Data : Robot->Parameter->Signal Parameter->Dedicated Input/Output Assignment->Data.
    Then you need to output IODATA input to the robot for at least 15 ms before inputing OVRDSEL signal.
Similar Threads
  • PLC Speed Override
    • Birch8101
    • June 20, 2022 at 3:18 PM
    • KUKA Robot Forum
  • Fanuc R30iA
    • bill4807
    • December 1, 2021 at 3:45 AM
    • Fanuc Robot Forum
  • NX100 robot at standstill feedback
    • Robottech
    • January 21, 2021 at 11:59 PM
    • Yaskawa Motoman Robot Forum
  • Dynamic base offset changing
    • Adam.C
    • December 8, 2020 at 12:56 PM
    • KUKA Robot Forum
  • Kuka is pausing for a while when sending the analog output command to PLC
    • issam dahaweir
    • September 30, 2020 at 10:55 AM
    • KUKA Robot Forum
  • Fanuc Robot with Schneider PLC
    • mathias39
    • May 23, 2019 at 10:04 AM
    • Fanuc Robot Forum
  • Change robot speed in PickMaster3
    • blizz1993
    • August 2, 2019 at 2:54 PM
    • ABB Robot Forum
  • Changing the robot speed on the fly, mid-movement
    • buontempone
    • July 24, 2019 at 6:01 PM
    • Kawasaki Robot Forum
  • Welding speed and override
    • cyber-weld
    • July 25, 2019 at 11:52 AM
    • Fanuc Robot Forum
  • NX100 SRCH-instruction
    • gpunkt
    • October 16, 2018 at 9:14 AM
