I am only given the option to add a b Vario but not a P Vario, am I overlooking something.?
Xrc controller
Willgerr -
August 16, 2022 at 1:27 PM -
Are you trying to use the ADD instruction?
If so, if you press SELECT on the ADD instruction in the INFORM LIST this will put the ADD on the Edit Buffer LIne. Press SELECT again to get into the Detail Edit screen. Cursor right one time to the chevron. Press SELECT again. In the drop-down you should have P.
Thanx for the quick assistance. I tried that but it only gives me the following options:
B
B[ ]
I. I[ ]. And D
See photo
Keep cursoring down. There may be more options available. The older versions of firmware did not have arrows to show there are more options.
Agree with RoboProf. The controller is set to expanded language. If you cursor down you should see more. There should be the D[ ], P, and P[ ].
Wow thanx guys, I really missed the obvious with this one. It's all there.
Regards and great work on this excellent site.
